[mpich-discuss] make fails with undefined reference	VALGRIND_CHECK_MEM_IS_ADDRESSABLE
    Dave Goodell
    goodell at mcs.anl.gov
    Tue May 18 14:08:13 CDT 2010
Darius made a good point out-of-band.  Are you using mpd?  If so, can you try using hydra instead?  MPD's process mapping support has been flaky in the past, and could possibly cause this sort of error.
http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager
-Dave
On May 18, 2010, at 1:46 PM, Dave Goodell wrote:
> That sounds like an unrelated issue.  Can you slap strace on there and see what file open is failing to open?
> -Dave
> On May 18, 2010, at 1:40 PM, Wei-keng Liao wrote:
>> Hi, Dave,
>> I tried your approach by removing "meminit" from "--enable-g" and deleting lines 25-35 of "src/include/mpiu_valgrind.h", but got the following errors when ran a simple hello program.
>> I am using "--enable-g=dbg".
>> % mpiexec -l -n 4 hello
>> 3: Fatal error in MPI_Init: Other MPI error, error stack:
>> 3: MPIR_Init_thread(394).................: Initialization failed
>> 3: MPID_Init(135)........................: channel initialization failed
>> 3: MPIDI_CH3_Init(43)....................:
>> 3: MPID_nem_init(202)....................:
>> 3: MPIDI_CH3I_Seg_commit(366)............:
>> 3: MPIU_SHMW_Hnd_deserialize(358)........:
>> 3: MPIU_SHMW_Seg_open(897)...............:
>> 3: MPIU_SHMW_Seg_create_attach_templ(671): open failed - No such file or directory
>> rank 3 in job 9  aum0.cse.psu.edu_33436   caused collective abort of all ranks
>> exit status of rank 3: return code 1
>> Wei-keng
>> On May 18, 2010, at 12:31 PM, Dave Goodell wrote:
>>> Yeah, that's the reason.  I'll make some adjustments to the build system to handle this.
>>> -Dave
>>> On May 18, 2010, at 11:50 AM, Wei-keng Liao wrote:
>>>> It is valgrind-2.4.0
>>>> Wei-keng
>>>> On May 18, 2010, at 11:45 AM, Anthony Chan wrote:
>>>>> How about "valgrind --version" ?
>>>>> ----- "Wei-keng Liao" <wkliao at ece.northwestern.edu> wrote:
>>>>>> I checked valgrind.h on my system, but do not know how to tell the
>>>>>> valgrind version. Let me know if you have an idea.
>>>>>> Wei-keng
>>>>>> On May 18, 2010, at 10:51 AM, Dave Goodell wrote:
>>>>>>> What version of valgrind do you have installed?
>>>>>>> I suspect that your version of valgrind is older than anything that
>>>>>>> we've tested with and is slipping between the gap of "is valgrind.h
>>>>>>> available" and "does valgrind.h work".  I can strengthen the
>>>>>>> configure test if I have an idea of what version of valgrind you
>>>>>> have.
>>>>>>> In the interim, the best workaround for you is probably to either
>>>>>>> remove "meminit" from your "--enable-g" arg, hack up the configure
>>>>>>> tests for valgrind so that they always fail, or delete lines 25-35
>>>>>>> of "src/include/mpiu_valgrind.h".
>>>>>>> -Dave
>>>>>>> On May 18, 2010, at 10:38 AM, Wei-keng Liao wrote:
>>>>>>>> When running make of mpich2-1.2.1p1, I got an error complaining
>>>>>>>> undefined reference to VALGRIND_CHECK_MEM_IS_ADDRESSABLE. Please
>>>>>>>> see the attached standard outputs from configure and make.
>>>>>>>> The configure command and environment variables used are also given
>>>>>>>> in out.configure file.
>>>>>>>> I am using GNU compilers, gcc and gfortran, to build MPICH2.
>>>>>>>> gcc version 4.0.2 20051125 (Red Hat 4.0.2-8)
>>>>>>>> % rpm -q glibc
>>>>>>>> glibc-2.3.6-3
>>>>>>>> % uname -a
>>>>>>>> Linux 2.6.17-1.2142_FC4smp #1 SMP Tue Jul 11 22:57:02 EDT 2006 i686
>>>>>>>> athlon i386 GNU/Linux
>>>>>>>> Wei-keng
>>>>>>>> <out.configure><out.make>
>>>>>>>> _______________________________________________
>>>>>>>> mpich-discuss mailing list
>>>>>>>> mpich-discuss at mcs.anl.gov
>>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
