[mpich-discuss] mpich-discuss Digest, Vol 20, Issue 23
    Dave Goodell
    goodell at mcs.anl.gov
    Tue May 18 08:25:53 CDT 2010
Please use a newer version of MPICH2.  MPICH2 1.1 is relatively old.  The latest stable release is 1.2.1p1 and the current preview release is 1.3a2.
Your python version seems reasonable and ought to be compatible, but I haven't seen this error before in MPD.  It may have been fixed in one of the newer releases.
-Dave
On May 18, 2010, at 2:45 AM, Hei Xia wrote:
>   My python version is 2.5.2 and the version of mpich is mpich 2-1.1.
>   Is there anything wrong?
> Message: 4
> Date: Mon, 17 May 2010 09:16:19 -0500
> From: Dave Goodell <goodell at mcs.anl.gov>
> Subject: Re: [mpich-discuss] "mpd -e" && "mpd -h -p " could not
>        comunicate      with each other.
> To: mpich-discuss at mcs.anl.gov
> Message-ID: <5126CF85-DE6E-44DD-83FD-727DCF915AE1 at mcs.anl.gov>
> Content-Type: text/plain; charset=us-ascii
> Sounds like a python version compatibility issue.  What version of python are you using ("python --version")?
> However, I would recommend dispensing with MPD altogether and use the hydra process manager instead: http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager
> -Dave
> On May 17, 2010, at 8:51 AM, Hei Xia wrote:
> >       hi,everyone!
> >       I want to run mpirun on two pc computers.I have installed mpich2 on them and configured them. However it doesn't work.
> >       I checked like this(on the two pcs):
> >       1. mpdcheck -pc     --> all right
> >       2.mpdcheck -l         --> all right
> >       3.mpdcheck -f mpd.hosts   --> all right
> >       4.mpdcheck -f mpd.hosts  -ssh  --> right on pc 1 ,but wrong on pc 2,the error message is :
> >          Traceback (most recent call last):
> >   File "/usr/bin/mpdcheck", line 517, in ?
> >     cmd2 = "ssh %s -x -n %s%smpdcheck.py -c %s %s" % (host,fullDirName,path.sep,
> > fqhn1,port)
> > AttributeError: 'module' object has no attribute 'sep'
> >       5. on pc 1 :  mpdcheck -s
> >          on pc 2 : mpdcheck -c host port
> >          It does not work too.
> >     what's wrong with it?
> >      Thank you.
> > _______________________________________________
> > mpich-discuss mailing list
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
