[mpich-discuss] mpich-discuss Digest, Vol 20, Issue 23
    Hei Xia
    heixia108 at gmail.com
    Tue May 18 02:45:01 CDT 2010
  My python version is 2.5.2 and the version of mpich is mpich 2-1.1.
  Is there anything wrong?
> Message: 4
> Date: Mon, 17 May 2010 09:16:19 -0500
> From: Dave Goodell <goodell at mcs.anl.gov>
> Subject: Re: [mpich-discuss] "mpd -e" && "mpd -h -p " could not
>        comunicate      with each other.
> To: mpich-discuss at mcs.anl.gov
> Message-ID: <5126CF85-DE6E-44DD-83FD-727DCF915AE1 at mcs.anl.gov>
> Content-Type: text/plain; charset=us-ascii
> Sounds like a python version compatibility issue.  What version of python
> are you using ("python --version")?
> However, I would recommend dispensing with MPD altogether and use the hydra
> process manager instead:
> http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager
> -Dave
> On May 17, 2010, at 8:51 AM, Hei Xia wrote:
> >       hi,everyone!
> >       I want to run mpirun on two pc computers.I have installed mpich2 on
> them and configured them. However it doesn't work.
> >       I checked like this(on the two pcs):
> >       1. mpdcheck -pc     --> all right
> >       2.mpdcheck -l         --> all right
> >       3.mpdcheck -f mpd.hosts   --> all right
> >       4.mpdcheck -f mpd.hosts  -ssh  --> right on pc 1 ,but wrong on pc
> 2,the error message is :
> >          Traceback (most recent call last):
> >   File "/usr/bin/mpdcheck", line 517, in ?
> >     cmd2 = "ssh %s -x -n %s%smpdcheck.py -c %s %s" %
> (host,fullDirName,path.sep,
> > fqhn1,port)
> > AttributeError: 'module' object has no attribute 'sep'
> >       5. on pc 1 :  mpdcheck -s
> >          on pc 2 : mpdcheck -c host port
> >          It does not work too.
> >     what's wrong with it?
> >      Thank you.
> > _______________________________________________
> > mpich-discuss mailing list
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100518/da1a0d3c/attachment.htm>
