[mpich-discuss] MPICH2's predefined reduce operation can not support quadruple precision
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Thu May 13 11:32:09 CDT 2010
 I am currently trying to see if I can recreate your problem (Cygwin+MPICH2 compilation error).
 The ticket pointed out in the discussion (https://trac.mcs.anl.gov/projects/mpich2/ticket/1028), may or may not be related to your problem (Atleast the error messages are different).
 Did you get the error message with MPICH2 on windows (Installed using the MSI installer on windows) or cygwin (Installed using configure/make/make install) ? Which version of MPICH2 are you using (on windows)?
Jayesh
----- Original Message -----
Sent: Thursday, May 13, 2010 8:35:51 AM GMT -06:00 US/Canada Central
Subject: Re: [mpich-discuss] MPICH2's predefined reduce operation can not support quadruple precision
I don't know much about Windows/Cygwin. I'll let our windows expert take
this over.
  -- Pavan
On 05/12/2010 03:10 AM, Jilong Yin wrote:
> Sorry, I did not capture the stderr output, that is
> make[3]: Entering directory
> `/home/nakata093/mpich2-trunk-r6642/src/util/mem'
>   CC              trmem.c
>   CC              handlemem.c
>   CC              safestr.c
>   CC              argstr.c
>   CC              strerror.c
> strerror.c:13: error: conflicting types for ‘strerror_r’
> /usr/include/string.h:69: error: previous declaration of ‘strerror_r’
> was here
> strerror.c: In function ‘MPIU_Strerror’:
> strerror.c:28: warning: assignment makes pointer from integer without a cast
> make[3]: *** [strerror.o] Error 1
> make[3]: Leaving directory `/home/nakata093/mpich2-trunk-r6642/src/util/mem'
> make[2]: *** [all-redirect] Error 2
> make[2]: Leaving directory `/home/nakata093/mpich2-trunk-r6642/src/util'
> make[1]: *** [all-redirect] Error 2
> make[1]: Leaving directory `/home/nakata093/mpich2-trunk-r6642/src'
> make: *** [all-redirect] Error 2
> 2010/5/12 Jilong Yin <yinjilong at gmail.com <mailto:yinjilong at gmail.com>>
>     Sorry, I can not compile MPICH2 correctly
>     (I haven't compile MPICH2 before by myself)
>     My computer is Windows 7 (64bit) .
>     I tried to compile under Cygwin. But when compiling it , I got
>     errors as attached file.
>     Though it is mostly my mistake, but maybe you can help me
>     Thank you a lot.
>     2010/5/12 Pavan Balaji <balaji at mcs.anl.gov <mailto:balaji at mcs.anl.gov>>
>         The ticket you point out in your test program
>         (https://trac.mcs.anl.gov/projects/mpich2/ticket/1028) has been
>         fixed in r6426 as mentioned on the ticket. Did you try the
>         nightly snapshots
>         (http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/nightly/trunk)?
>         If not, can you try them out and see if you are still seeing
>         this problem?
>         Thanks,
>          -- Pavan
>         On 05/11/2010 08:24 PM, Jilong Yin wrote:
>                Hello,
>                  MPICH2's  predefined reduce operation  seems it can not
>             support
>                quadruple precision.
>                  I used the attached  program to test this. And got the
>             following
>                error message,
>             Fatal error in PMPI_Reduce: Invalid MPI_Op, error stack:
>             PMPI_Reduce(1198).......: MPI_Reduce(sbuf=0012FF00,
>             rbuf=0012FF10, count=1, dtyp
>             e=0x4c00102b, MPI_SUM, root=0, MPI_COMM_WORLD) failed
>             MPIR_SUM_check_dtype(97): MPI_Op MPI_SUM operation not
>             defined for this datatype
>                  If so, is there any plan to support this ?
>                 Thank you.
>                YIN
>             _______________________________________________
>             mpich-discuss mailing list
>             mpich-discuss at mcs.anl.gov <mailto:mpich-discuss at mcs.anl.gov>
>             https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>         Pavan Balaji
>         http://www.mcs.anl.gov/~balaji <http://www.mcs.anl.gov/%7Ebalaji>
Pavan Balaji
