[mpich-discuss] MPICH2's predefined reduce operation can not support quadruple precision
Pavan Balaji
balaji at mcs.anl.gov
Thu May 13 08:35:51 CDT 2010
I don't know much about Windows/Cygwin. I'll let our windows expert take
this over.
-- Pavan
On 05/12/2010 03:10 AM, Jilong Yin wrote:
> Sorry, I did not capture the stderr output, that is
> make[3]: Entering directory
> `/home/nakata093/mpich2-trunk-r6642/src/util/mem'
> CC trmem.c
> CC handlemem.c
> CC safestr.c
> CC argstr.c
> CC strerror.c
> strerror.c:13: error: conflicting types for ‘strerror_r’
> /usr/include/string.h:69: error: previous declaration of ‘strerror_r’
> was here
> strerror.c: In function ‘MPIU_Strerror’:
> strerror.c:28: warning: assignment makes pointer from integer without a cast
> make[3]: *** [strerror.o] Error 1
> make[3]: Leaving directory `/home/nakata093/mpich2-trunk-r6642/src/util/mem'
> make[2]: *** [all-redirect] Error 2
> make[2]: Leaving directory `/home/nakata093/mpich2-trunk-r6642/src/util'
> make[1]: *** [all-redirect] Error 2
> make[1]: Leaving directory `/home/nakata093/mpich2-trunk-r6642/src'
> make: *** [all-redirect] Error 2
> 2010/5/12 Jilong Yin <yinjilong at gmail.com <mailto:yinjilong at gmail.com>>
> Sorry, I can not compile MPICH2 correctly
> (I haven't compile MPICH2 before by myself)
> My computer is Windows 7 (64bit) .
> I tried to compile under Cygwin. But when compiling it , I got
> errors as attached file.
> Though it is mostly my mistake, but maybe you can help me
> Thank you a lot.
> 2010/5/12 Pavan Balaji <balaji at mcs.anl.gov <mailto:balaji at mcs.anl.gov>>
> The ticket you point out in your test program
> (https://trac.mcs.anl.gov/projects/mpich2/ticket/1028) has been
> fixed in r6426 as mentioned on the ticket. Did you try the
> nightly snapshots
> (http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/nightly/trunk)?
> If not, can you try them out and see if you are still seeing
> this problem?
> Thanks,
> -- Pavan
> On 05/11/2010 08:24 PM, Jilong Yin wrote:
> Hello,
> MPICH2's predefined reduce operation seems it can not
> support
> quadruple precision.
> I used the attached program to test this. And got the
> following
> error message,
> Fatal error in PMPI_Reduce: Invalid MPI_Op, error stack:
> PMPI_Reduce(1198).......: MPI_Reduce(sbuf=0012FF00,
> rbuf=0012FF10, count=1, dtyp
> e=0x4c00102b, MPI_SUM, root=0, MPI_COMM_WORLD) failed
> MPIR_SUM_check_dtype(97): MPI_Op MPI_SUM operation not
> defined for this datatype
> If so, is there any plan to support this ?
> Thank you.
> YIN
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov <mailto:mpich-discuss at mcs.anl.gov>
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji <http://www.mcs.anl.gov/%7Ebalaji>
Pavan Balaji
