[mpich-discuss] Asking standard checkpoint in MPICH2
Bagus Jati Santoso
bagus.jati at gmail.com
Mon May 10 22:10:35 CDT 2010
Hi Darius,
OK. Thank you for answer my email.
And how about MPICH-1.2.1.p1? The more stable version one..
Do I need to install BLCR first for this version?
Since 1.2.p1 have a support for BLCR too, which version do you suggest to
work with BLCR package, 1.2.1.p1 or 1.3a2 ?
Thank you very much,
Bagus
On Tue, May 11, 2010 at 4:17 AM, Darius Buntinas <buntinas at mcs.anl.gov>wrote:
> Hi Bagus,
> Sorry, I haven't written up the documentation on this yet. You'll need to
> install BLCR, and configure mpich2 with the following configure options:
> --with-hydra-ckpointlib=blcr --enable-checkpointing
> If you didn't install BLCR in a standard system location (e.g., if you
> installed it in your home directory), then you'll need to specify the
> install location using the --with-blcr= configure option as well. Also,
> make sure that your LD_LIBRARY_PATH is set correctly if necessary.
> Once you configure and make, you'll need to make sure the BLCR kernel
> modules are loaded on each machine. Use the -ckpoint-interval option for
> mpiexec to specify how often to take checkpoints. You'll also need to
> specify the location where the checkpoint files should be written using the
> -ckpoint-prefix option (make sure the directory exists).
> To restart from a checkpoint specify the same number of processes as the
> original run and the -ckpoint-prefix option, but leave off the name of the
> executable.
> Let us know how this works for you. Remember that you're using a beta
> version, so you might still encounter some bugs.
> -d
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100511/43575902/attachment.htm>
