[mpich-discuss] Asking standard checkpoint in MPICH2
Darius Buntinas
buntinas at mcs.anl.gov
Mon May 10 15:17:34 CDT 2010
Hi Bagus,
Sorry, I haven't written up the documentation on this yet. You'll need
to install BLCR, and configure mpich2 with the following configure options:
--with-hydra-ckpointlib=blcr --enable-checkpointing
If you didn't install BLCR in a standard system location (e.g., if you
installed it in your home directory), then you'll need to specify the
install location using the --with-blcr= configure option as well. Also,
make sure that your LD_LIBRARY_PATH is set correctly if necessary.
Once you configure and make, you'll need to make sure the BLCR kernel
modules are loaded on each machine. Use the -ckpoint-interval option
for mpiexec to specify how often to take checkpoints. You'll also need
to specify the location where the checkpoint files should be written
using the -ckpoint-prefix option (make sure the directory exists).
To restart from a checkpoint specify the same number of processes as the
original run and the -ckpoint-prefix option, but leave off the name of
the executable.
Let us know how this works for you. Remember that you're using a beta
version, so you might still encounter some bugs.
-d
On 05/10/2010 05:46 AM, Bagus Jati Santoso wrote:
> Dear all members,
> I have some question. But first, I've installed MPICH2 in my cluster (11
> computers).
> It is my cluster specification :
> -Debian 5
> -MPICH2-1.3a2 (by download the package)
> and BLCR package hasn't installed yet
> Since websites said that there is BLCR-based checkpointing feature in
> standard MPICH2, I want to do little modification with BLCR mechanism in
> MPICH2-1.3a2.
> I have try to modify it in one week, but it didn't give significant
> progress.
> So, my question are :
> 1. Is it true that blcr have already embedded in MPICH2-1.3a2 package?
> 2. ckpoint_blcr.c calls many standard cr function. And I've succesfully
> run checkpointing MPICH2 standard mechanism for my MPI program.
> But I didn't find the file that contain definintion of
> cr_checkpoint, cr_poll_checkpoint, and others. Where can I find ?
> 3. Where is the location of libcr.h? ckpoint_blcr.c call this function.
> Do I need to install BLCR package first?
> 4. Do nyone have idea how to modify blcr mechanism in MPICH or how to
> create our checkpoint/restart mechanism?
> Please answer my question. Thank you so much for your attention.
> Best regards,
> Bagus
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
