[mpich-discuss] Asking for help on MPI derived data type
Jilong Yin
yinjilong at gmail.com
Fri May 7 20:50:00 CDT 2010
I don't want to describe the entire combination of A&B
But I want to describe of the combination of one slice of A and one slice of
B.
As an example, I divide the integer array A into 10 slices, each slice has
one element
and divide double array B into 10 slices, each slice has 10 element.
I wonder how I can construct a data type to combine of the two kind of
slices together. And then I can exchange data between slices.
slice array A to 10 parts as A(1) A(2) A(3) A(4) ..
.....A(10)
slice array B to 10 parts as B(1:10) B(11:20) B(21:30)
B(31:40)......B(91:100)
>From your comment, it seems impossible in MPI.
(As a stupid method, by now I define a lot of data types for every slice
combinations and it can works)
Anyway, thank you for your kind help.
2010/5/7 Dave Goodell <goodell at mcs.anl.gov>
> Are you trying to construct a type to describe the entire combination of A
> & B at once, or a type to describe just the slice such that if you passed it
> to MPI_Send with count=10 then it would send the entire combination? The
> former should be possible with MPI_Type_create_struct but I don't think that
> the latter is possible in MPI.
> -Dave
> On May 7, 2010, at 12:16 AM, Jilong Yin wrote:
> In an other word, can I define derived data type for two array slices with
>> different data type and different slice size ?
>> For example,
>> integer A(10)
>> double precision B(100)
>> .. .....A(10)
>> Can I define a derived data type to describe each part?
>> C(1): A(1) B(1:10)
>> C(2): A(2) B(11:20)
>> Thank you for your any comment.
>> 2010/5/7 Jilong Yin <yinjilong at gmail.com>
>> Hello,
>> I am trying to define MPI derived data type to simplify my program.
>> But I can not get it working properly.
>> First I describe the basic thing about the following test program.
>> There are many layers consisting by many nodes. Each node has a
>> position(x,y,z) ( real data type )and a bound condition type description in
>> (x,y,z) direction( integer data) .
>> I want to send i-th layer node data in a so-called buffer space to j-th
>> layer node in a so-called computation space.
>> I first define two MPI derived data types to describing node layer data.
>> And then using the new data type to exchange data between the two space.
>> The following is my FORTRAN code, though it can be compiled and run , the
>> result is wrong.
>> Can anyone help me out?
>> Thank you .
>> JILONG YIN
>> 2010-05-07
>> [CODE]
>> C The following program is used to test MPI derived data type in parallel
>> finite element program
>> C The node data in buffer space will be send to computation space
>> PROGRAM TEST
>> IMPLICIT NONE
>> INCLUDE 'MPIF.H'
>> C The number of nodes on a crossection
>> INTEGER,PARAMETER::N_NOD_CROSEC=10
>> C The number of nodes along the longitude direction
>> INTEGER,PARAMETER::N_NOD_STREAM=13
>> C The number of total nodes
>> INTEGER,PARAMETER::N_NOD=N_NOD_CROSEC*N_NOD_STREAM
>> C Derived data type for node layer data buffer space
>> INTEGER NOD_LAY_DATA_BF(N_NOD_STREAM)
>> C The node position data in buffer space
>> DOUBLE PRECISION POSITION_BF(3,N_NOD)
>> C The node boundary condition type data in buffer space
>> INTEGER IFLAG_BD_COND_BF(3,N_NOD)
>> C Derived data type for node layer data computation space
>> INTEGER NOD_LAY_DATA(N_NOD_STREAM)
>> C The node position data in computation space
>> DOUBLE PRECISION POSITION(3,N_NOD)
>> C The node boundary condition type data in computation space
>> INTEGER IFLAG_BD_COND(3,N_NOD)
>> C Some varibles for defining MPI derived data type
>> INTEGER IBLOCK(99),IDISP(99),ITYPE(99)
>> INTEGER NBLOCK
>> C Node data type(for buffer space and computation space)
>> INTEGER NOD_LAY_DATA_BF_TYPE
>> INTEGER NOD_LAY_DATA_TYPE
>> C MPI function status return
>> INTEGER::ISTATUS(MPI_STATUS_SIZE),IERR
>> C My rank
>> INTEGER MYID
>> C source rank and destination rank ID
>> INTEGER ID_SRC,ID_DEST
>> C node layer number for sending and receiving
>> INTEGER ISNS,IRNS
>> INTEGER I,J,NOD1,NOD2
>> C Initilize the MPI enviroment
>> CALL MPI_INIT(IERR)
>> C Get the rank ID
>> CALL MPI_COMM_RANK(MPI_COMM_WORLD,MYID,IERR)
>> C----------------------------------------------------------
>> C Define node layer derived data type for buffer space
>> NBLOCK=0
>> NBLOCK=NBLOCK+1
>> IBLOCK(NBLOCK)=1
>> ITYPE(NBLOCK)=MPI_INTEGER
>> CALL MPI_ADDRESS(NOD_LAY_DATA_BF,IDISP(NBLOCK),IERR)
>> C Node position
>> NBLOCK=NBLOCK+1
>> IBLOCK(NBLOCK)=3*N_NOD_CROSEC
>> ITYPE(NBLOCK)=MPI_DOUBLE_PRECISION
>> CALL MPI_ADDRESS(POSITION_BF,IDISP(NBLOCK),IERR)
>> C Node boundary condition type
>> NBLOCK=NBLOCK+1
>> CALL MPI_ADDRESS(IFLAG_BD_COND_BF,IDISP(NBLOCK),IERR)
>> C convert to relative address
>> DO I=NBLOCK,1,-1
>> IDISP(I)=IDISP(I)-IDISP(1)
>> END DO
>> C generate new derived data type
>> CALL MPI_TYPE_STRUCT(NBLOCK,IBLOCK,IDISP,ITYPE,
>> & NOD_LAY_DATA_BF_TYPE,IERR)
>> CALL MPI_TYPE_COMMIT(NOD_LAY_DATA_BF_TYPE,IERR)
>> C Define node layer derived data type for computation space
>> C
>> NBLOCK=0
>> NBLOCK=NBLOCK+1
>> IBLOCK(NBLOCK)=1
>> CALL MPI_ADDRESS(NOD_LAY_DATA,IDISP(NBLOCK),IERR)
>> C Node position
>> NBLOCK=NBLOCK+1
>> CALL MPI_ADDRESS(POSITION,IDISP(NBLOCK),IERR)
>> NBLOCK=NBLOCK+1
>> CALL MPI_ADDRESS(IFLAG_BD_COND(1,1),IDISP(NBLOCK),IERR)
>> DO I=NBLOCK,1,-1
>> END DO
>> & NOD_LAY_DATA_TYPE,IERR)
>> CALL MPI_TYPE_COMMIT(NOD_LAY_DATA_TYPE,IERR)
>> CC---------------------------------------------------------
>> C Node data initilize for computation space
>> NOD_LAY_DATA(:)=0
>> POSITION(:,:)=0.0D0
>> IFLAG_BD_COND(:,:)=-1
>> C Prepare test data for buffer space
>> DO I=1,N_NOD_STREAM
>> NOD_LAY_DATA_BF(I)=I
>> END DO
>> DO I=1,N_NOD
>> DO J=1,3
>> POSITION_BF(J,I)=J+I*10.0D0
>> IFLAG_BD_COND_BF(J,I)=J+I*10+90000000
>> END DO
>> END DO
>> C I will send the ISNS-th layer node data in buffer space to IRNS-th layer
>> node data in computation space
>> ISNS=1
>> IRNS=2
>> C This is the source rank id and destination rank id
>> ID_SRC=0
>> ID_DEST=1
>> C send node layer data using derived data type 1
>> IF(MYID.EQ.ID_SRC) THEN
>> CALL MPI_SEND(NOD_LAY_DATA_BF(ISNS),1,NOD_LAY_DATA_BF_TYPE,
>> & ID_DEST,123,MPI_COMM_WORLD,IERR)
>> END IF
>> C receive node layer data using derived data type 2
>> IF(MYID.EQ.ID_DEST) THEN
>> CALL MPI_RECV(NOD_LAY_DATA(IRNS),1,NOD_LAY_DATA_TYPE,
>> & ID_SRC,123,MPI_COMM_WORLD,ISTATUS,IERR)
>> END IF
>> print*,'Myid=',MYID,'IERR=',ierr
>> C output the received data to verify them
>> PRINT*,ID_SRC,NOD_LAY_DATA_BF(ISNS),
>> & ID_DEST,NOD_LAY_DATA(IRNS)
>> DO I=1,N_NOD_CROSEC
>> NOD1=I+(ISNS-1)*N_NOD_CROSEC
>> NOD2=I+(IRNS-1)*N_NOD_CROSEC
>> PRINT*,NOD1,POSITION_BF(1,NOD1),NOD2,POSITION(1,NOD2)
>> PRINT*,NOD1,POSITION_BF(2,NOD1),NOD2,POSITION(2,NOD2)
>> PRINT*,NOD1,POSITION_BF(3,NOD1),NOD2,POSITION(3,NOD2)
>> PRINT*,NOD1,IFLAG_BD_COND_BF(1,NOD1),NOD2,IFLAG_BD_COND(1,NOD2)
>> PRINT*,NOD1,IFLAG_BD_COND_BF(2,NOD1),NOD2,IFLAG_BD_COND(2,NOD2)
>> PRINT*,NOD1,IFLAG_BD_COND_BF(3,NOD1),NOD2,IFLAG_BD_COND(3,NOD2)
>> END DO
>> END IF
>> c
>> CALL MPI_TYPE_FREE(NOD_LAY_DATA_BF_TYPE,IERR)
>> CALL MPI_TYPE_FREE(NOD_LAY_DATA_TYPE,IERR)
>> CALL MPI_FINALIZE(IERR)
>> END
>> [/CODE]
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100508/09451f27/attachment.htm>
