[mpich-discuss] Asking for help on MPI derived data type
Dave Goodell goodell at mcs.anl.gov
Fri May 7 09:11:58 CDT 2010
Are you trying to construct a type to describe the entire combination
of A & B at once, or a type to describe just the slice such that if
you passed it to MPI_Send with count=10 then it would send the entire
combination?  The former should be possible with
MPI_Type_create_struct but I don't think that the latter is possible
in MPI.
-Dave
On May 7, 2010, at 12:16 AM, Jilong Yin wrote:
> In an other word, can I define derived data type for two array
> slices with different data type and different slice size ?
> For example,
>   integer A(10)
>  double precision B(100)
> slice array A to 10 parts as  A(1)        A(2)        A(3)
> A(4)   ..  .....A(10)
> slice array B to 10 parts as  B(1:10)   B(11:20)  B(21:30)
> B(31:40)......B(91:100)
> Can I define a derived data type to describe  each part?
>  C(1): A(1)  B(1:10)
>  C(2): A(2)  B(11:20)
> Thank you for your any comment.
> 2010/5/7 Jilong Yin <yinjilong at gmail.com>
> Hello,
>   I am trying to define MPI derived data type to simplify my program.
>   But I can not get it working properly.
>   First I describe the basic thing about the following test program.
>   There are many layers consisting by many nodes. Each node has a
> position(x,y,z) ( real data type )and a bound condition  type
> description in (x,y,z) direction( integer data) .
>   I want to send i-th layer node data in a so-called buffer space to
> j-th layer node in a so-called computation space.
>   I first define two MPI derived data types to describing node layer
> data. And then using the new data type to exchange data between the
> two space.
>   The following is my FORTRAN code, though it can be compiled and
> run , the result is wrong.
>   Can anyone help me  out?
>   Thank you .
> JILONG YIN
>  2010-05-07
> [CODE]
> C The following program is used to test MPI derived data type in
> parallel finite element program
> C The node data in buffer space will be send to computation space
>       PROGRAM TEST
>     IMPLICIT NONE
>     INCLUDE 'MPIF.H'
> C The number of nodes on a crossection
>       INTEGER,PARAMETER::N_NOD_CROSEC=10
> C The number of nodes along the longitude direction
>     INTEGER,PARAMETER::N_NOD_STREAM=13
> C The number of total nodes
>     INTEGER,PARAMETER::N_NOD=N_NOD_CROSEC*N_NOD_STREAM
> C Derived data type for node layer data buffer space
>     INTEGER NOD_LAY_DATA_BF(N_NOD_STREAM)
> C The node position data  in buffer space
>     DOUBLE PRECISION POSITION_BF(3,N_NOD)
> C The node boundary condition type data in buffer space
>     INTEGER IFLAG_BD_COND_BF(3,N_NOD)
> C Derived data type for node layer data computation space
>     INTEGER NOD_LAY_DATA(N_NOD_STREAM)
> C The node position data  in computation space
>     DOUBLE PRECISION POSITION(3,N_NOD)
> C The node boundary condition type data in computation space
>     INTEGER IFLAG_BD_COND(3,N_NOD)
> C Some varibles for defining MPI derived data type
>     INTEGER IBLOCK(99),IDISP(99),ITYPE(99)
>     INTEGER NBLOCK
> C Node data type(for buffer space and computation space)
>       INTEGER NOD_LAY_DATA_BF_TYPE
>       INTEGER NOD_LAY_DATA_TYPE
> C MPI function status return
>     INTEGER::ISTATUS(MPI_STATUS_SIZE),IERR
> C My rank
>     INTEGER MYID
> C source rank and destination rank ID
>     INTEGER ID_SRC,ID_DEST
> C node layer number for sending and receiving
>     INTEGER ISNS,IRNS
>     INTEGER I,J,NOD1,NOD2
> C Initilize the MPI enviroment
>     CALL MPI_INIT(IERR)
> C Get the rank ID
>       CALL MPI_COMM_RANK(MPI_COMM_WORLD,MYID,IERR)
> C----------------------------------------------------------
> C Define node layer derived data type for buffer space
>       NBLOCK=0
>       NBLOCK=NBLOCK+1
>     IBLOCK(NBLOCK)=1
>     ITYPE(NBLOCK)=MPI_INTEGER
>     CALL MPI_ADDRESS(NOD_LAY_DATA_BF,IDISP(NBLOCK),IERR)
> C Node position
>       NBLOCK=NBLOCK+1
>     IBLOCK(NBLOCK)=3*N_NOD_CROSEC
>     ITYPE(NBLOCK)=MPI_DOUBLE_PRECISION
>     CALL MPI_ADDRESS(POSITION_BF,IDISP(NBLOCK),IERR)
> C Node boundary condition type
>       NBLOCK=NBLOCK+1
>     CALL MPI_ADDRESS(IFLAG_BD_COND_BF,IDISP(NBLOCK),IERR)
> C convert to relative address
>     DO I=NBLOCK,1,-1
>       IDISP(I)=IDISP(I)-IDISP(1)
>     END DO
> C generate new derived data type
>     CALL MPI_TYPE_STRUCT(NBLOCK,IBLOCK,IDISP,ITYPE,
>      &                     NOD_LAY_DATA_BF_TYPE,IERR)
>       CALL MPI_TYPE_COMMIT(NOD_LAY_DATA_BF_TYPE,IERR)
> C Define node layer derived data type for computation space
> C
>       NBLOCK=0
>       NBLOCK=NBLOCK+1
>     IBLOCK(NBLOCK)=1
>     CALL MPI_ADDRESS(NOD_LAY_DATA,IDISP(NBLOCK),IERR)
> C Node position
>       NBLOCK=NBLOCK+1
>     CALL MPI_ADDRESS(POSITION,IDISP(NBLOCK),IERR)
>       NBLOCK=NBLOCK+1
>     CALL MPI_ADDRESS(IFLAG_BD_COND(1,1),IDISP(NBLOCK),IERR)
>     DO I=NBLOCK,1,-1
>     END DO
>      &                     NOD_LAY_DATA_TYPE,IERR)
>       CALL MPI_TYPE_COMMIT(NOD_LAY_DATA_TYPE,IERR)
> CC---------------------------------------------------------
> C Node data initilize for computation space
>       NOD_LAY_DATA(:)=0
>     POSITION(:,:)=0.0D0
>     IFLAG_BD_COND(:,:)=-1
> C Prepare test data for buffer space
>       DO I=1,N_NOD_STREAM
>       NOD_LAY_DATA_BF(I)=I
>     END DO
>       DO I=1,N_NOD
>       DO J=1,3
>         POSITION_BF(J,I)=J+I*10.0D0
>           IFLAG_BD_COND_BF(J,I)=J+I*10+90000000
>       END DO
>     END DO
> C I will send the ISNS-th layer node data in buffer space to IRNS-th
> layer node data in computation space
>     ISNS=1
>     IRNS=2
> C This is the source rank id and destination rank id
>     ID_SRC=0
>     ID_DEST=1
> C send node layer data using derived data type 1
>     IF(MYID.EQ.ID_SRC) THEN
>         CALL MPI_SEND(NOD_LAY_DATA_BF(ISNS),1,NOD_LAY_DATA_BF_TYPE,
>      &                ID_DEST,123,MPI_COMM_WORLD,IERR)
>     END IF
> C receive node layer data using derived data type 2
>     IF(MYID.EQ.ID_DEST) THEN
>           CALL MPI_RECV(NOD_LAY_DATA(IRNS),1,NOD_LAY_DATA_TYPE,
>      &                  ID_SRC,123,MPI_COMM_WORLD,ISTATUS,IERR)
>     END IF
>     print*,'Myid=',MYID,'IERR=',ierr
> C output the received data to verify them
>     PRINT*,ID_SRC,NOD_LAY_DATA_BF(ISNS),
>      &       ID_DEST,NOD_LAY_DATA(IRNS)
>     DO I=1,N_NOD_CROSEC
>       NOD1=I+(ISNS-1)*N_NOD_CROSEC
>       NOD2=I+(IRNS-1)*N_NOD_CROSEC
>       PRINT*,NOD1,POSITION_BF(1,NOD1),NOD2,POSITION(1,NOD2)
>       PRINT*,NOD1,POSITION_BF(2,NOD1),NOD2,POSITION(2,NOD2)
>       PRINT*,NOD1,POSITION_BF(3,NOD1),NOD2,POSITION(3,NOD2)
>     PRINT*,NOD1,IFLAG_BD_COND_BF(1,NOD1),NOD2,IFLAG_BD_COND(1,NOD2)
>     PRINT*,NOD1,IFLAG_BD_COND_BF(2,NOD1),NOD2,IFLAG_BD_COND(2,NOD2)
>     PRINT*,NOD1,IFLAG_BD_COND_BF(3,NOD1),NOD2,IFLAG_BD_COND(3,NOD2)
>     END DO
>     END IF
> c
>       CALL MPI_TYPE_FREE(NOD_LAY_DATA_BF_TYPE,IERR)
>       CALL MPI_TYPE_FREE(NOD_LAY_DATA_TYPE,IERR)
>     CALL MPI_FINALIZE(IERR)
>     END
> [/CODE]
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
