[mpich-discuss] Clarification of my question
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Tue May  4 16:42:31 CDT 2010
 If the user registered is a local user then you need to have the same user (same username/password) available on all the nodes. However you need to register the username/password only on the node where you launch your job.
 It is recommended to register a domain user since you don't have to keep track of local users on each compute node.
Jayesh
----- Original Message -----
Sent: Tuesday, May 4, 2010 3:11:10 PM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] Clarification of my question
I assume that by specifying "Everyone" on the install, the smpd will allow any run id on Node 0 to start a run and all smpd's will participate in the ring. But is there any kind of authentication limitations on the compute/smpd ring nodes that require a local user id to allow the run to proceed?
mpich-discuss mailing list
