[mpich-discuss] handle_mpd_output 374
    Dave Goodell
    goodell at mcs.anl.gov
    Mon Mar 29 09:59:04 CDT 2010
It's hard to say what the problem is, although it sounds like a
networking configuration problem.  Did you try the troubleshooting
steps listed in Appendix A of the Installer's Guide?  In particular,
did you try the steps that use the "mpdcheck" utility?
http://www.mcs.anl.gov/research/projects/mpich2/documentation/files/mpich2-1.2.1-installguide.pdf
Alternatively, you can try the Hydra process manager instead: http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager
-Dave
On Mar 28, 2010, at 11:27 PM, guchonglin-6 wrote:
> Hello, i use MPICH2.
> I use this command
>  mpdboot -n 2 -f  mpd.hosts
> but find the following output
> mpdboot_linux-k0dn (handle_mpd_output 374): failed to ping mpd on
> node1; recvd output={}
> [1]+  Done                    mpd
> So, I need help and good advice.
>        Thank
>  you!
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
