[mpich-discuss] [HELP] Cannot start mpd
    Dave Goodell
    goodell at mcs.anl.gov
    Mon Mar 29 09:57:40 CDT 2010
It's hard to say what the problem is, although it sounds like a
networking configuration problem.  Did you try the troubleshooting
steps listed in Appendix A of the Installer's Guide?  In particular,
did you try the steps that use the "mpdcheck" utility?
http://www.mcs.anl.gov/research/projects/mpich2/documentation/files/mpich2-1.2.1-installguide.pdf
-Dave
On Mar 29, 2010, at 6:04 AM, 甜瓜 wrote:
> Howdy,
> It is my first time to use MPICH2. To explain my case clear, there are
> two node, named n1 and n2 respectively.
> I downloaded the latest source code and compiled it in n1 by default
> "make". Then I copy all files into n2.
> SSH trust and etc/hosts are configured.
> Case 1: start mpd on n1, OK.
> Case 2: start “mpd --trace" on n2, stuck at:
>             n2_60857: ENTER mpd_sockpair in
> /home/sl/mpi/bin/mpdlib.py at line 213; ARGS=()
> Case 3: start "mpdboot -n 2 -f mpd.hosts" on n1, OK. mpdtrace on each
> node shows "n1, n2"
>            mpdringtest OK.
>            mpiexec -n 2 date   // Fail, mpiexec_n1 (mpiexec 392): no
> msg recvd from mpd when expecting ack of request
> Case 4: start "mpdboot -n 2 -f mpd.hosts" on n2, failed with nothing
> output.
> Could you point out the reason?
> ShenLei
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
