[mpich-discuss] The working of mapall option on windows
    Jeyapandian Kottalam
    JKottalam at reactiondesign.com
    Sun Mar 21 15:54:50 CDT 2010
Thank you. This is helpful. My take-home message is that I should use the -mapall option on the mpiexec command whenever I expect the program to do i/o on mapped drives.
I have another question on mpiexec options. What exactly is the difference between using -localonly and -host localhost? On this machine I had trouble with -mapall, -localonly works and -host localhost does not work even with -mapall, even when the machine is always on the network. How do these options impact the ability to undock laptops while an MPI program is running?
Thanks
Kottalam
-----Original Message-----
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: Friday, March 19, 2010 12:07 PM
To: Jeyapandian Kottalam
Cc: mpich-discuss at mcs.anl.gov
Subject: Re: [mpich-discuss] The working of mapall option on windows
 The mapped network drives should be visible to the process launcher, mpiexec.exe, on the local machine since the process launcher runs under the security context of the local user (i.e., You run the job launcher as the user logged on to the machine). However the mapped folders are not available to the process manager on the remote machine unless you explicitly map them (On the remote machine SMPD impersonates as the user running the job, however network drives are not mapped automatically).
 You should also note that although the MPI program on a network mapped drive is visible to the process launcher without any explicit mapping, the MPI process itself won't be able to access the mapped drive (read a file from network mapped drive within your MPI program) unless you explicitly map them.
 Hope it helps.
Jayesh
----- Original Message -----
From: "Jeyapandian Kottalam" <JKottalam at reactiondesign.com>
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Thursday, March 18, 2010 5:00:10 PM GMT -06:00 US/Canada Central
Subject: RE: [mpich-discuss] The working of mapall option on windows
I just compared the Properties and Advanced Security tabs of this drive on both computers. These are desktop computers plugged in to the network all the time. So they have not been made available offline. The only thing that is turned on, on both machines is "Allow indexing services" for fast searching.
- Kottalam
Sent: Thursday, March 18, 2010 7:10 AM
 Do you have any special settings for the network drives (eg: "Make available offline" )?
Jayesh
To: jayesh at mcs.anl.gov
Sent: Wednesday, March 17, 2010 4:35:10 PM GMT -06:00 US/Canada Central
Hi Jayesh
I am just running on a single machine with multiple cores. On both machines I start the program using the commands
mpiexec -n 2 program
mpiexec -mapall -n 2 program
The latter behaves the same on both machines, but the former works on only one of them. On the other machine it stops without finding the input file (which is on a mapped drive).
Thanks
Kottalam
From: jayesh at mcs.anl.gov [mailto:jayesh at mcs.anl.gov]
Sent: Wednesday, March 17, 2010 10:51 AM
 Can you provide the complete mpiexec command that you use to launch your MPI program ? Are you running the MPI jobs locally on each machine (MPI processes belonging to the job are launched only on the localhost)?
Jayesh
Sent: Wednesday, March 17, 2010 10:49:31 AM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] The working of mapall option on windows
Hi
I have built my program with MPICH2 1.0.8p1 on Windows XP. My input and output files are on mapped drives. I run the program on two different Windows XP machines and get different behaviors. On one machine, I can run the program with or without the -mapall option on mpiexec. On the other machine, the program works only with the -mapall option. On both machines the drives are always mapped at the OS level. Both machines are configured identically as far as I can tell; in fact one was cloned from the other. For supporting my users, I would like to understand why it works on one machine without the -mapall option but not on the other. Where would I look for the differences in configuration?
Thanks
Kottalam
mpich-discuss mailing list
