[mpich-discuss] clean up after MPI_Cart_create
    burlen
    burlen.loring at gmail.com
    Thu Mar 18 05:50:26 CDT 2010
Is there a way to clean up after MPI_Cart_create ? Other wise it leaks
some resources and pollutes valgrind output.
Thanks
Burlen
==22729== Memcheck, a memory error
detector
==22729== Copyright (C) 2002-2009, and GNU GPL'd, by Julian Seward et
al.
==22729== Using Valgrind-3.5.0-Debian and LibVEX; rerun with -h for
copyright info
==22729== Command:
./TestSubArrayWriter
==22729==
leaked context IDs detected: mask=0x54b31a0
mask[0]=0x7fffffff
In direct memory block for handle type ATTR, 1 handles are still
allocated
In direct memory block for handle type KEYVAL, 1 handles are still
allocated
In direct memory block for handle type COMM, 1 handles are still
allocated
[0] 8 at [0x0000000006416bf8],
cart_create.c[154]
[0] 8 at [0x0000000006416b08],
cart_create.c[152]
[0] 8 at [0x0000000006416a18],
cart_create.c[150]
[0] 56 at [0x00000000064168f8],
cart_create.c[144]
[0] 8 at [0x0000000006416538],
local_proc.c[91]
[0] 8 at [0x0000000006416448],
local_proc.c[90]
[0] 24 at [0x0000000006416168],
mpid_vc.c[79]
 ==22729==
==22729== HEAP SUMMARY:
==22729==     in use at exit: 1,240 bytes in 7 blocks
==22729==   total heap usage: 164 allocs, 149 frees, 8,509,866 bytes
allocated
==22729==
==22729== 168 bytes in 1 blocks are definitely lost in loss record 4 of 7
==22729==    at 0x4C25153: malloc (vg_replace_malloc.c:195)
==22729==    by 0x521C386: MPIU_trmalloc (trmem.c:230)
==22729==    by 0x517DD14: MPIU_Find_local_and_external (local_proc.c:90)
==22729==    by 0x511FAE1: MPIR_Comm_commit (commutil.c:228)
==22729==    by 0x511E31B: PMPI_Comm_split (comm_split.c:384)
==22729==    by 0x50C06BA: MPIR_Cart_create (cart_create.c:119)
==22729==    by 0x50C1A8F: PMPI_Cart_create (cart_create.c:298)
==22729==    by 0x50C1E7C: MPI_CART_CREATE (cart_createf.c:199)
==22729==    by 0x402EC4: __cartesiandecompmodule_MOD_createcommunicator
(CartesianDecompModule.f90:194)
==22729==    by 0x40325A:
__cartesiandecompmodule_MOD_initializecartesiandecomp_u
(CartesianDecompModule.f90:66)
==22729==    by 0x40190D: MAIN__ (TestSubArrayWriter.f90:76)
==22729==    by 0x403369: main (in
/home/burlen/ext/MPI-IO/TestSubArrayWriter)
==22729==
==22729== 168 bytes in 1 blocks are definitely lost in loss record 5 of 7
==22729==    by 0x517DD47: MPIU_Find_local_and_external (local_proc.c:91)
==22729==
==22729== 184 bytes in 1 blocks are definitely lost in loss record 6 of 7
==22729==    by 0x51A9D59: MPID_VCRT_Create (mpid_vc.c:79)
==22729==    by 0x511E135: PMPI_Comm_split (comm_split.c:365)
==22729==
==22729== 552 (216 direct, 336 indirect) bytes in 1 blocks are
definitely lost in loss record 7 of 7
==22729==    by 0x50C07A0: MPIR_Cart_create (cart_create.c:143)
==22729==
==22729== LEAK SUMMARY:
==22729==    definitely lost: 736 bytes in 4 blocks
==22729==    indirectly lost: 336 bytes in 2 blocks
==22729==      possibly lost: 0 bytes in 0 blocks
==22729==    still reachable: 168 bytes in 1 blocks
==22729==         suppressed: 0 bytes in 0 blocks
==22729== Reachable blocks (those to which a pointer was found) are not
shown.
==22729== To see them, rerun with: --leak-check=full --show-reachable=yes
==22729==
==22729== For counts of detected and suppressed errors, rerun with: -v
==22729== ERROR SUMMARY: 4 errors from 4 contexts (suppressed: 4 from 4)
