[mpich-discuss] Node vs CPU control
Dave Goodell goodell at mcs.anl.gov
Fri Mar 19 12:50:11 CDT 2010
If you drop the ":4" from the end of each line of your hostfile then
processes will be assigned in round-robin order (nodeA, nodeB,
nodeC, ..., nodeA, nodeB, etc).  This will spread your processes out
in the 16-process case, but in the 64-process case your ranks will not
be assigned sequentially to each node.  That may or may not be a
problem for your applications.
If you want a sequential mapping sometimes and a round-robin mapping
other times, you will need to use two different host files and specify
the non-default one via "mpiexec -machinefile your_file OTHER_ARGS".
-Dave
On Mar 19, 2010, at 11:22 AM, Robertson, Andrew wrote:
> Folks,
> I have a 16 node cluster with 4 cpus per node. I would like to just
> leave an mpd up and running that was booted on all 16 nodes with
> four cpus per node.
> Ie
> NodeName:4
> On each line of my hosts file
> Is there a way to force jobs which use less than the full cluster
> to  spread out and use an equal number of CPUs on each node? I find
> that  if for instance I ask for 16 cpus I get four nodes with four
> cpus each, I would like to get 16 nodes with on cpu each?
> Still getting the hang of all this
> Any help is appreciated
> Thanks
> -Andy
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
