[mpich-discuss] mpich2-1.2.1p1 - cannot	create	regular	file`/index.htm': Permission denied
    Scott Atchley
    atchley at myri.com
    Fri Mar 19 12:38:34 CDT 2010
Hi all,
I ran into the same problem today with 1.2.1p1 on Centos5.4. I had to manually edit src/pm/hydra/Makefile.in and prepend $(top_srcdir) before several mpl items. See the attached patch. After patching, configure and make were happy.
Scott
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100319/f5848cbd/attachment.obj>
On Mar 11, 2010, at 5:01 PM, Pavan Balaji wrote:
> No, the point is the user should not need to use autotools at all if
> building from the released tarball.
> The problem that was happening was that MPL has some time stamp for
> aclocal.m4 that it creates, and then Hydra goes and overwrites it,
> creating a dependency mess within the Makefile.
> -- Pavan
> On 03/11/2010 03:53 PM, Anthony Chan wrote:
>> Pavan,
>> This guy's system is pretty old, he does not seem to have the autotools
>> needed to rebuild the configure and Makefile.in involved.
>> A.Chan
>> ----- "Pavan Balaji" <balaji at mcs.anl.gov> wrote:
>>> Ah, I should have seen this earlier. My guess is that you are running
>>> into the autotools ordering issue that we fixed in r6292
>>> (http://trac.mcs.anl.gov/projects/mpich2/changeset/6292).
>>> Can you try out the latest nightly snapshot to see if the problem
>>> still
>>> exists?
>>> http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/nightly/trunk
>>> -- Pavan
>>> On 03/11/2010 03:34 PM, Rajeev Thakur wrote:
>>>> We build MPICH2 quite routinely following the exact steps in the
>>> README
>>>> file, so something strange is happening in your specific case.
>>>> Rajeev
>>>>    *From:* mpich-discuss-bounces at mcs.anl.gov
>>>>    [mailto:mpich-discuss-bounces at mcs.anl.gov] *On Behalf Of
>>> *Preeti
>>>>    *Sent:* Thursday, March 11, 2010 1:26 PM
>>>>    *To:* mpich-discuss at mcs.anl.gov
>>>>    *Subject:* Re: [mpich-discuss] mpich2-1.2.1p1 - cannot create
>>>>    Hi
>>>>    Thanks for the replies, but I get following errors.
>>>>    1. If I do only build in /tmp
>>>>    cannot create regular file `/index.htm': Permission denied
>>>>    2. if I do everything in /tmp, then the following error.
>>>>     " Making all in mpl
>>>>    /bin/sh: line 17: cd: mpl: No such file or directory
>>>>    make[3]: *** [all-recursive] Error 1"
>>>>    I have sent both log files earlier.
>>>>    Yes, the /home/vss is network file system. I have no root access
>>> to
>>>>    the system.
>>>>    Is there any way out of this?
>>>>    Please help.
>>>>    Thanks
>>>>    Preeti
>>>>    On Thu, Mar 11, 2010 at 11:18 PM, Rajeev Thakur
>>> <thakur at mcs.anl.gov
>>>>    <mailto:thakur at mcs.anl.gov>> wrote:
>>>>        Just untar and build it again on a local disk. The install
>>> directory
>>>>        (--prefix option to configure) can be on NFS.
>>>>        Rajeev
>>>>> -----Original Message-----
>>>>> From: mpich-discuss-bounces at mcs.anl.gov
>>>>        <mailto:mpich-discuss-bounces at mcs.anl.gov>
>>>>        <mailto:mpich-discuss-bounces at mcs.anl.gov>] On Behalf Of
>>>>> chan at mcs.anl.gov <mailto:chan at mcs.anl.gov>
>>>>> Sent: Thursday, March 11, 2010 11:48 AM
>>>>> To: mpich-discuss at mcs.anl.gov
>>> <mailto:mpich-discuss at mcs.anl.gov>
>>>>> Subject: Re: [mpich-discuss] mpich2-1.2.1p1 - cannot
>>> create
>>>>> Is your /home/vss a local filesystem or some type
>>>>> network file system ?  If /home/vss is a network
>>>>> filesystem, the problem could be incorrect clock
>>>>> on the filesystem. If so, could you copy
>>>>> everything to a local filesystem like /tmp(assuming
>>>>> it is big enough) and try again ?
>>>>> ----- "Preeti" <preeti at csa.iisc.ernet.in
>>>>        <mailto:preeti at csa.iisc.ernet.in>> wrote:
>>>>>> Hello
>>>>>> I have rebuilt everything without setting the flags
>>> also
>>>>>> /home/vss/preeti/bin/mpich2-1.2.1p1/configure
>>>>>> --prefix=/home/vss/preeti/bin/2-1.2.1build --enable-f90
>>> 2>&1
>>>>        | tee
>>>>>> c.log
>>>>>> make 2>&1 | tee m.log
>>>>>> make install 2>&1 | tee mi.log
>>>>>> and this time I get the following error
>>>>>> /usr/bin/install -c -m 644 index.htm /index.htm
>>>>>> /usr/bin/install: cannot create regular file
>>> `/index.htm':
>>>>> Permission
>>>>>> denied
>>>>>> mkdir: cannot create directory `/www1': Permission
>>> denied
>>>>>> The log files are attached.
>>>>>> What am I missing?
>>>>>> Appreciate your help.
>>>>>> Thanks
>>>>>> Preeti
>>>>>> On Thu, Mar 11, 2010 at 4:37 PM, Preeti
>>>>>> wrote:
>>>>>>> Hello
>>>>>>> I have rebuilt everything from scratch and did vpath
>>> build.
>>>>>>> I set the following
>>>>>>> export F90=gfortran
>>>>>>> export F77=gfortran
>>>>>>> export LD_LIBRARY_PATH=/usr/lib64:/lib:/usr/lib
>>>>>>> export LD_RUN_PATH=/usr/lib64:/lib:/usr/lib
>>>>>>> --prefix=/home/vss/preeti/bin/2-1.2.1p1 --enable-f90
>>> 2>&1
>>>>        | tee
>>>>>> c.log
>>>>>>> Then I get the error
>>>>>>> Making all in mpl
>>>>>>> The files are attached.
>>>>>>> Please help.
>>>>>>> Thanks
>>>>>>> Preeti
>>>>>>> On Thu, Mar 11, 2010 at 1:53 AM, <chan at mcs.anl.gov
>>>>        <mailto:chan at mcs.anl.gov>> wrote:
>>>>>>>> I don't think setting F77 and F90 causes the problem
>>> that
>>>>>>>> you are seeing.  The directories or subpackges that
>>> have
>>>>>>>> problems use a different build system than the
>>> majority of
>>>>>>>> mpich2 base, so it could be that there is bugs in
>>> the
>>>>> build system
>>>>>>>> in those subpackage.
>>>>>>>> Since you didn't do "make distclean" before you
>>>>        reconfigure, so
>>>>>>>> the m.log(.old) do not tell me much. Can you rebuild
>>>>        everything
>>>>>>>> from scratch ?  i.e. untar the mpich2 tarball in a
>>> different
>>>>>> location.
>>>>>>>> Instead of doing an inpath build (i.e. cd
>>> mpich2-1.2.1p1/ ;
>>>>>>>> ./configure....),
>>>>>>>> could you do a VPATH build as documented in the
>>> README
>>>>> (search for
>>>>>> the
>>>>>>>> word VPATH)?  Send us the configure and make outputs
>>> again
>>>>>>>> (be sure to add 2>&1 in creating the output files).
>>>>>>>> A.Chan
>>>>>>>>> Hello
>>>>>>>>> Thank you for the quick response.
>>>>>>>>> I forgot to mention that I had set two flags
>>> earlier.
>>>>>>>>> export F90=gfortran
>>>>>>>>> export F77=gfortran
>>>>>>>>> The earlier problem is gone when I compiled without
>>> setting
>>>>>> these. I
>>>>>>>>> am
>>>>>>>>> attaching all log files, the earlier ones and the
>>> new ones.
>>>>>>>>> Now I am facing another error which is from "make
>>>>        install 2>& |
>>>>>> tee
>>>>>>>>> mi.log"
>>> `/index.htm':
>>>>>> Permission
>>>>>>>>> denied
>>>>>>>>> Probably some variable is not set. I tried setting
>>>>        docdir too.
>>>>>>>>> mi.log is also attached.
>>>>>>>>> Please help.
>>>>>>>>> Thanks
>>>>>>>>> Preeti
>>>>>>>>> On Wed, Mar 10, 2010 at 9:33 PM, <chan at mcs.anl.gov
>>>>>>>>>> It is unclear what went wrong based on what
>>> you've
>>>>> provided so
>>>>>> far.
>>>>>>>>>> Can you send us the configure and make outputs
>>> as
>>>>        stated in
>>>>>> the
>>>>>>>>>> README (be sure to include the stderr in the
>>> output
>>>>        file) ?
>>>>>>>>>>> Hello
>>>>>>>>>>> I am trying to install mpich2-1.2.1p1 on a
>>> 64-bit Linux
>>>>>> system.
>>>>>>>>>>> Configuration was successful.
>>>>>>>>>>> ./configure --prefix=$HOME/local/mpich2-1.2.1
>>>>> --enable-f90 |
>>>>>> tee
>>>>>>>>>>> c.log
>>>>>>>>>> BTW, you didn't include stderr in c.log.  Depends
>>> on
>>>>> the shell
>>>>>> you
>>>>>>>>>> use, you need to either add "&" or "2>&1".  See
>>>>        README for
>>>>>>>>> details..
>>>>>>>>>> A.Chan
>>>>>>>>>> _______________________________________________
>>>>>>>>>> mpich-discuss mailing list
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>>>>>>>>>> This message has been scanned for viruses and
>>>>>>>>>> dangerous content by MailScanner, and is
>>>>>>>>>> believed to be clean.
>>> Pavan Balaji
>>> http://www.mcs.anl.gov/~balaji
> Pavan Balaji
