[mpich-discuss] open failed for root's mpd conf
    rcx11 at yahoo.com
    rcx11 at yahoo.com
    Wed Mar 17 18:34:13 CDT 2010
Output is:
stat64("/home/sd-t2/.mpd.conf", {st_mode=S_IFREG|0600, st_size=51, ...}) = 0
open("/home/sd-t2/.mpd.conf", O_RDONLY|O_LARGEFILE) = 3
[pid 22875] open("/etc/mpd.conf", O_RDONLY) = 5
--- On Wed, 3/17/10, Dave Goodell <goodell at mcs.anl.gov> wrote:
> From: Dave Goodell <goodell at mcs.anl.gov>
> Subject: Re: [mpich-discuss] open failed for root's mpd conf
> To: mpich-discuss at mcs.anl.gov
> Date: Wednesday, March 17, 2010, 5:20 PM
> Oops, I omitted something important
> from that strace command.  It should read like this
> instead:
> -----8<-----
> strace -f -e trace=file mpiexec echo foo 2>&1 | grep
> mpd.conf
> -----8<-----
> -Dave
> On Mar 17, 2010, at 5:10 PM, Dave Goodell wrote:
> > OK, I suppose that theory didn't pan out.
> > You could try something like the following to see why
> the open for "/etc/mpd.conf" is failing, but you will need a
> setuid root version of strace:
> > -----8<-----
> > strace -f -e trace=file 2>&1 | grep mpd.conf
> > -----8<-----
> > I don't remember exactly how to get a proper setuid
> strace installation, although it may be as simple as "sudo
> chmod u+s /path/to/strace ; sudo chown root
> /path/to/strace".  Please be aware that allowing
> arbitrary users to execute setuid root strace is a *huge*
> local security hole.  So if this is a multi-user system
> then you should restrict execution to users in a trusted
> group and only mess around with this on a copy of the
> file.  See the strace man page if you want to go down
> this path.
> > Or just run the mpd ring as your user.  I
> wouldn't personally recommend running something as fragile
> as mpd as root anyway, even though it is technically
> possible.
> > Alternatively, ditch mpd altogether and try the hydra
> process manager: http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager
> > It doesn't require setting up any daemons in the
> common case.
> > -Dave
> > On Mar 17, 2010, at 4:51 PM, rcx11 at yahoo.com
> wrote:
> >> Output of "strings /usr/bin/mpdroot | grep etc"
> yielded "/etc/mpd.conf" Setting the environment variable
> failed. I made a symlink to /etc/mpd.conf in
> /usr/etc/mpd.conf. This also failed.
> root's mpd conf
> >>> Date: Wednesday, March 17, 2010, 4:33 PM
> >>> Well, if my earlier suggestion about
> >>> "/etc/mpd.conf" doesn't solve the problem,
> then I am not
> >>> entirely sure what is going on.
> >>> I just took a peek at the code and it looks
> like we may
> >>> have a bug in the root mpd.conf search path
> that was
> >>> introduced in r5844.  We now search
> >>> "@sysconfdir@/mpd.conf" (which expands to
> >>> "${prefix}/etc/mpd.conf" normally) instead of
> >>> "/etc/mpd.conf".  So I'm betting that you
> have a valid
> >>> "/etc/mpd.conf" but mpdroot is looking for it
> in
> >>> "/usr/etc/mpd.conf" instead.
> >>> Can you try two things for me?  First run
> the
> >>> following command and send us the output:
> "strings
> >>> /usr/bin/mpdroot | grep etc".  Second,
> try setting the
> "MPD_CONF_FILE=/etc/mpd.conf" before
> >>> running mpiexec.  That may let you work
> around the
> >>> problem for now.  Alternatively you could
> probably move
> >>> your "/etc/mpd.conf" to the "/usr/etc/"
> directory.
> >>> -Dave
> >>> On Mar 17, 2010, at 3:59 PM, rcx11 at yahoo.com
> >>> wrote:
> >>>> That is exactly what I'm trying to do -
> run on a root
> >>> started ring as a normal user. I get no errors
> when running
> >>> as root.
> failed for
> >>> root's mpd conf
> >>>>> Date: Wednesday, March 17, 2010, 3:46
> PM
> >>>>> Just to be sure, you are trying to to
> >>>>> use a root-started mpd ring as a
> >>>>> regular user, correct?  If so,
> make sure that
> >>> you have
> >>>>> a mode 600 file
> >>>>> named "/etc/mpd.conf" (no leading ".")
> containing
> >>> the
> >>>>> secret word.
> >>>>> If you are trying to use a regular
> user-started
> >>> mpd ring as
> >>>>> a regular
> >>>>> user, then remove
> "MPD_USE_ROOT_MPD=yes" from
> >>> your
> >>>>> "~/.mpd.conf".
> >>>>> -Dave
> >>>>> On Mar 17, 2010, at 3:33 PM, rcx11 at yahoo.com
> >>>>> wrote:
> >>>>>> It's "MPD_USE_ROOT_MPD=yes" as per
> setup guide
> >>> in the
> >>>>> link given.
> open failed
> >>> for
> >>>>> root's mpd conf
> 2010, 3:02 PM
> >>>>>>> On Mar 17, 2010, at 2:50 PM,
> rcx11 at yahoo.com
> >>>>>>> wrote:
> >>>>>>>> I've been searching
> through
> >>> documentation
> >>>>> trying to
> >>>>>>> find why I'm getting the error
> when trying
> >>> to run
> >>>>> as a
> >>>>>>> non-root user. I'm running
> Fedora 12 x86
> >>> and have
> >>>>> installed
> >>>>>>> MPICH2 via yum. I've got my
> mpd.conf files
> >>> created
> >>>>> according
> >>>>>>> to http://debianclusters.cs.uni.edu/index.php/MPICH_without_Torque_Functionality
> >>>>>>> When trying to run mpiexec as
> a non-root
> >>> user, I
> >>>>> get the
> >>>>>>> error "/usr/bin/mpdroot: open
> failed for
> >>> root's
> >>>>> mpd conf
> filempiexec_sebastian.ags-rolla.zapto.org
> >>>>> (__init__ 1208):
> >>>>>>> forked process failed;
> status=255" What is
> >>> causing
> >>>>> this?
> >>>>>>> Please see section 5.1.6 of
> the
> >>> Installer's Guide:
> >>>>> http://www.mcs.anl.gov/research/projects/mpich2/documentation/files/mpich2-1.2.1-installguide.pdf
> >>>>>>> Do you have
> "MPD_USE_ROOT_MPD=1" set
> >>> somewhere in
> >>>>> your
> >>>>>>> environment or mpd.conf file?
> >>>>>>> -Dave
> >>>>>>> mpich-discuss mailing list
> >>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
