[mpich-discuss] open failed for root's mpd conf
Dave Goodell
goodell at mcs.anl.gov
Wed Mar 17 16:33:56 CDT 2010
Well, if my earlier suggestion about "/etc/mpd.conf" doesn't solve the
problem, then I am not entirely sure what is going on.
I just took a peek at the code and it looks like we may have a bug in
the root mpd.conf search path that was introduced in r5844. We now
search "@sysconfdir@/mpd.conf" (which expands to "${prefix}/etc/
mpd.conf" normally) instead of "/etc/mpd.conf". So I'm betting that
you have a valid "/etc/mpd.conf" but mpdroot is looking for it in "/
usr/etc/mpd.conf" instead.
Can you try two things for me? First run the following command and
send us the output: "strings /usr/bin/mpdroot | grep etc". Second,
try setting the environment variable "MPD_CONF_FILE=/etc/mpd.conf"
before running mpiexec. That may let you work around the problem for
now. Alternatively you could probably move your "/etc/mpd.conf" to
the "/usr/etc/" directory.
-Dave
On Mar 17, 2010, at 3:59 PM, rcx11 at yahoo.com wrote:
> That is exactly what I'm trying to do - run on a root started ring
> as a normal user. I get no errors when running as root.
> --- On Wed, 3/17/10, Dave Goodell <goodell at mcs.anl.gov> wrote:
>> From: Dave Goodell <goodell at mcs.anl.gov>
>> Subject: Re: [mpich-discuss] open failed for root's mpd conf
>> To: mpich-discuss at mcs.anl.gov
>> Date: Wednesday, March 17, 2010, 3:46 PM
>> Just to be sure, you are trying to to
>> use a root-started mpd ring as a
>> regular user, correct? If so, make sure that you have
>> a mode 600 file
>> named "/etc/mpd.conf" (no leading ".") containing the
>> secret word.
>> If you are trying to use a regular user-started mpd ring as
>> a regular
>> user, then remove "MPD_USE_ROOT_MPD=yes" from your
>> "~/.mpd.conf".
>> -Dave
>> On Mar 17, 2010, at 3:33 PM, rcx11 at yahoo.com
>> wrote:
>>> It's "MPD_USE_ROOT_MPD=yes" as per setup guide in the
>> link given.
>> root's mpd conf
>>>> Date: Wednesday, March 17, 2010, 3:02 PM
>>>> On Mar 17, 2010, at 2:50 PM, rcx11 at yahoo.com
>>>> wrote:
>>>>> I've been searching through documentation
>> trying to
>>>> find why I'm getting the error when trying to run
>> as a
>>>> non-root user. I'm running Fedora 12 x86 and have
>> installed
>>>> MPICH2 via yum. I've got my mpd.conf files created
>> according
>>>> to http://debianclusters.cs.uni.edu/index.php/MPICH_without_Torque_Functionality
>>>> When trying to run mpiexec as a non-root user, I
>> get the
>>>> error "/usr/bin/mpdroot: open failed for root's
>> mpd conf
>>>> filempiexec_sebastian.ags-rolla.zapto.org
>> (__init__ 1208):
>>>> forked process failed; status=255" What is causing
>> this?
>>>> Please see section 5.1.6 of the Installer's Guide:
>> http://www.mcs.anl.gov/research/projects/mpich2/documentation/files/mpich2-1.2.1-installguide.pdf
>>>> Do you have "MPD_USE_ROOT_MPD=1" set somewhere in
>> your
>>>> environment or mpd.conf file?
>>>> -Dave
>>>> _______________________________________________
>>>> mpich-discuss mailing list
>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
