[mpich-discuss] mpich2-1.2.1p1 - cannot create regular file	`/index.htm': Permission denied
    Dave Goodell
    goodell at mcs.anl.gov
    Thu Mar 11 11:30:50 CST 2010
For some reason the build system is attempting to re-run many of the
autotools (aclocal, autoheader, autoconf, etc) in some of the
subdirectories of your build.  These fail for various reasons,
including that your autotools versions aren't compatible with MPICH2.
The real problem is that the autotools are being re-run, you shouldn't
need to have them installed on your system at all.
When the various autotools fail to run correctly the build still
continues for some reason, but with many incorrect values set.  This
leads to the "cannot create regular file" errors that you are seeing.
Did you modify something in the source directory?  Perhaps a file
ending in ".in" or ".am" or ".sm"?  A fresh un-tar and build of
mpich2-1.2.1p1 shouldn't generally have this problem...
-Dave
On Mar 11, 2010, at 10:00 AM, Preeti wrote:
> Hello
> I have rebuilt everything without setting the flags also
> /home/vss/preeti/bin/mpich2-1.2.1p1/configure --prefix=/home/vss/
> preeti/bin/2-1.2.1build --enable-f90 2>&1 | tee c.log
> make 2>&1 | tee m.log
> make install 2>&1 | tee mi.log
> and this time I get the following error
> /usr/bin/install -c -m 644 index.htm /index.htm
> /usr/bin/install: cannot create regular file `/index.htm':
> Permission denied
> mkdir: cannot create directory `/www1': Permission denied
> The log files are attached.
> What am I missing?
> Appreciate your help.
> Thanks
> Preeti
> On Thu, Mar 11, 2010 at 4:37 PM, Preeti <preeti at csa.iisc.ernet.in>
> wrote:
> Hello
> I have rebuilt everything from scratch and did vpath build.
> I set the following
> export F90=gfortran
> export F77=gfortran
> export LD_LIBRARY_PATH=/usr/lib64:/lib:/usr/lib
> export LD_RUN_PATH=/usr/lib64:/lib:/usr/lib
> preeti/bin/2-1.2.1p1 --enable-f90 2>&1 | tee c.log
> Then I get the error
> Making all in mpl
> /bin/sh: line 17: cd: mpl: No such file or directory
> make[3]: *** [all-recursive] Error 1
> The files are attached.
> Please help.
> Thanks
> Preeti
> On Thu, Mar 11, 2010 at 1:53 AM, <chan at mcs.anl.gov> wrote:
> I don't think setting F77 and F90 causes the problem that
> you are seeing.  The directories or subpackges that have
> problems use a different build system than the majority of
> mpich2 base, so it could be that there is bugs in the build system
> in those subpackage.
> Since you didn't do "make distclean" before you reconfigure, so
> the m.log(.old) do not tell me much. Can you rebuild everything
> from scratch ?  i.e. untar the mpich2 tarball in a different location.
> Instead of doing an inpath build (i.e. cd mpich2-1.2.1p1/ ; ./
> configure....),
> could you do a VPATH build as documented in the README (search for the
> word VPATH)?  Send us the configure and make outputs again
> (be sure to add 2>&1 in creating the output files).
> A.Chan
> ----- "Preeti" <preeti at csa.iisc.ernet.in> wrote:
> > Hello
> > Thank you for the quick response.
> > I forgot to mention that I had set two flags earlier.
> > export F90=gfortran
> > export F77=gfortran
> > The earlier problem is gone when I compiled without setting these. I
> > am
> > attaching all log files, the earlier ones and the new ones.
> > Now I am facing another error which is from "make install 2>& | tee
> > mi.log"
> Permission
> > denied
> > Probably some variable is not set. I tried setting docdir too.
> > mi.log is also attached.
> > Please help.
> > Thanks
> > Preeti
> > On Wed, Mar 10, 2010 at 9:33 PM, <chan at mcs.anl.gov> wrote:
> > > It is unclear what went wrong based on what you've provided so
> far.
> > > Can you send us the configure and make outputs as stated in the
> > > README (be sure to include the stderr in the output file) ?
> > > > Hello
> > > > I am trying to install mpich2-1.2.1p1 on a 64-bit Linux system.
> > > > Configuration was successful.
> > > > ./configure --prefix=$HOME/local/mpich2-1.2.1 --enable-f90 | tee
> > > > c.log
> > > BTW, you didn't include stderr in c.log.  Depends on the shell you
> > > use, you need to either add "&" or "2>&1".  See README for
> > details..
> > > A.Chan
> > > _______________________________________________
> > > mpich-discuss mailing list
> > > mpich-discuss at mcs.anl.gov
> > > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> > > This message has been scanned for viruses and
> > > dangerous content by MailScanner, and is
> > > believed to be clean.
> c
> .log
> config
> .log><m.log><mi.log>_______________________________________________
