[mpich-discuss] mpich2-1.2.1p1 - cannot create regular file	`/index.htm': Permission denied
    Preeti
    preeti at csa.iisc.ernet.in
    Thu Mar 11 10:00:27 CST 2010
Hello
I have rebuilt everything without setting the flags also
/home/vss/preeti/bin/mpich2-1.2.1p1/configure
--prefix=/home/vss/preeti/bin/2-1.2.1build --enable-f90 2>&1 | tee c.log
make 2>&1 | tee m.log
make install 2>&1 | tee mi.log
and this time I get the following error
/usr/bin/install -c -m 644 index.htm /index.htm
/usr/bin/install: cannot create regular file `/index.htm': Permission denied
mkdir: cannot create directory `/www1': Permission denied
The log files are attached.
What am I missing?
Appreciate your help.
Thanks
Preeti
On Thu, Mar 11, 2010 at 4:37 PM, Preeti <preeti at csa.iisc.ernet.in> wrote:
> Hello
> I have rebuilt everything from scratch and did vpath build.
> I set the following
> export F90=gfortran
> export F77=gfortran
> export LD_LIBRARY_PATH=/usr/lib64:/lib:/usr/lib
> export LD_RUN_PATH=/usr/lib64:/lib:/usr/lib
> --prefix=/home/vss/preeti/bin/2-1.2.1p1 --enable-f90 2>&1 | tee c.log
> Then I get the error
> Making all in mpl
> /bin/sh: line 17: cd: mpl: No such file or directory
> make[3]: *** [all-recursive] Error 1
> The files are attached.
> Please help.
> Thanks
> Preeti
> On Thu, Mar 11, 2010 at 1:53 AM, <chan at mcs.anl.gov> wrote:
>> I don't think setting F77 and F90 causes the problem that
>> you are seeing.  The directories or subpackges that have
>> problems use a different build system than the majority of
>> mpich2 base, so it could be that there is bugs in the build system
>> in those subpackage.
>> Since you didn't do "make distclean" before you reconfigure, so
>> the m.log(.old) do not tell me much. Can you rebuild everything
>> from scratch ?  i.e. untar the mpich2 tarball in a different location.
>> Instead of doing an inpath build (i.e. cd mpich2-1.2.1p1/ ;
>> ./configure....),
>> could you do a VPATH build as documented in the README (search for the
>> word VPATH)?  Send us the configure and make outputs again
>> (be sure to add 2>&1 in creating the output files).
>> A.Chan
>> ----- "Preeti" <preeti at csa.iisc.ernet.in> wrote:
>> > Hello
>> > Thank you for the quick response.
>> > I forgot to mention that I had set two flags earlier.
>> > export F90=gfortran
>> > export F77=gfortran
>> > The earlier problem is gone when I compiled without setting these. I
>> > am
>> > attaching all log files, the earlier ones and the new ones.
>> > Now I am facing another error which is from "make install 2>& | tee
>> > mi.log"
>> > denied
>> > Probably some variable is not set. I tried setting docdir too.
>> > mi.log is also attached.
>> > Please help.
>> > Thanks
>> > Preeti
>> > On Wed, Mar 10, 2010 at 9:33 PM, <chan at mcs.anl.gov> wrote:
>> > > It is unclear what went wrong based on what you've provided so far.
>> > > Can you send us the configure and make outputs as stated in the
>> > > README (be sure to include the stderr in the output file) ?
>> > > > Hello
>> > > > I am trying to install mpich2-1.2.1p1 on a 64-bit Linux system.
>> > > > Configuration was successful.
>> > > > ./configure --prefix=$HOME/local/mpich2-1.2.1 --enable-f90 | tee
>> > > > c.log
>> > > BTW, you didn't include stderr in c.log.  Depends on the shell you
>> > > use, you need to either add "&" or "2>&1".  See README for
>> > details..
>> > > A.Chan
>> > > _______________________________________________
>> > > mpich-discuss mailing list
>> > > mpich-discuss at mcs.anl.gov
>> > > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>> > > This message has been scanned for viruses and
>> > > dangerous content by MailScanner, and is
>> > > believed to be clean.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100311/edeca846/attachment-0001.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100311/edeca846/attachment-0004.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100311/edeca846/attachment-0005.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100311/edeca846/attachment-0006.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100311/edeca846/attachment-0007.obj>
