[mpich-discuss] problem compiling svn trunk
    Thomas Ropars
    tropars at irisa.fr
    Mon Mar  8 16:18:47 CST 2010
After restarting my computer, I don't get any error anymore. I really
don't know what happened :(
Sorry for having disturbed you.
Thomas
chan at mcs.anl.gov a écrit :
> ----- "Thomas Ropars" <tropars at irisa.fr> wrote:
>> The location of the autotools are included in my PATH environment
>> variable.
>> The fact that I succesfully passed the tests for the autotool versions
>> doesn't mean that the script managed to find them ?
> Yes. I am not sure what went wrong in your case.  Can you
> rerun "maint/updatefiles" and send its output to us ?
> in csh-like shell:
> maint/updatefiles |& tee u.txtor
> or in sh-like shell:
> maint/updatefiles 2>&1 | tee u.txt
> Let's see if there is something wrong in u.txt.
> Also, tell us what system you are using.
> A.Chan
>> Thomas
>> The fact that I managed
>>> The error message indicated that autoconf couldn't be found
>>> when test/mpi/configure.in was processed.  If autoconf wasn't
>>> really there, the abort and error message should have happened
>> earlier!
>>> Did you set any environment variable to tell maint/updatefiles
>>> where autotools are located ?  i.e. autoconf, libtool and
>> automake..
>>> A.Chan
>>>> Hi,
>>>> I've just checkout mpich2 svn trunk. Following the process
>> described
>>>> here,
>> http://wiki.mcs.anl.gov/mpich2/index.php/Getting_And_Building_MPICH2,
>>>> I'm trying to run
>>>> ./maint/updatefiles
>>>> But I get the following error message:
>>>> Rebuilding all configure script because of missing confdbtimestamp
>>>> Found ./test/mpi/configure.in; executing make configure target
>>>> (cd . && autoheader -I ../../confdb && \
>>>> 	 -I ../../confdb )
>>>> /bin/sh: -I: not found
>>>> make: *** [configure] Erreur 127
>>>> See /local/tempo/mpich/mpich2/test/mpi/mf.tmp for Makefile that
>>>> failed
>>>> Error! Could not build configure in ./test/mpi with make configure
>>>> PANIC: Could not make configure from configure.in
>>>> In directory ./test/mpi
>>>> Regards,
>>>> Thomas
>>>> _______________________________________________
>>>> mpich-discuss mailing list
>>>> mpich-discuss at mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
