[mpich-discuss] problem compiling svn trunk
    chan at mcs.anl.gov
    chan at mcs.anl.gov
    Mon Mar  8 15:56:16 CST 2010
----- "Thomas Ropars" <tropars at irisa.fr> wrote:
> The location of the autotools are included in my PATH environment
> variable.
> The fact that I succesfully passed the tests for the autotool versions
> doesn't mean that the script managed to find them ?
Yes. I am not sure what went wrong in your case.  Can you
rerun "maint/updatefiles" and send its output to us ?
in csh-like shell:
maint/updatefiles |& tee u.txtor
or in sh-like shell:
maint/updatefiles 2>&1 | tee u.txt
Let's see if there is something wrong in u.txt.
Also, tell us what system you are using.
A.Chan
> Thomas
> The fact that I managed
> chan at mcs.anl.gov a écrit :
> > The error message indicated that autoconf couldn't be found
> > when test/mpi/configure.in was processed.  If autoconf wasn't
> > really there, the abort and error message should have happened
> earlier!
> > Did you set any environment variable to tell maint/updatefiles
> > where autotools are located ?  i.e. autoconf, libtool and
> automake..
> > A.Chan
> >> Hi,
> >> I've just checkout mpich2 svn trunk. Following the process
> described
> >> here,
> http://wiki.mcs.anl.gov/mpich2/index.php/Getting_And_Building_MPICH2,
> >> I'm trying to run
> >> ./maint/updatefiles
> >> But I get the following error message:
> >> Rebuilding all configure script because of missing confdbtimestamp
> >> Found ./test/mpi/configure.in; executing make configure target
> >> (cd . && autoheader -I ../../confdb && \
> >> 	 -I ../../confdb )
> >> /bin/sh: -I: not found
> >> make: *** [configure] Erreur 127
> >> See /local/tempo/mpich/mpich2/test/mpi/mf.tmp for Makefile that
> >> failed
> >> Error! Could not build configure in ./test/mpi with make configure
> >> PANIC: Could not make configure from configure.in
> >> In directory ./test/mpi
> >> Regards,
> >> Thomas
> >> _______________________________________________
> >> mpich-discuss mailing list
> >> mpich-discuss at mcs.anl.gov
> >> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
