[mpich-discuss] problem compiling svn trunk
    Thomas Ropars
    tropars at irisa.fr
    Mon Mar  8 14:49:43 CST 2010
The location of the autotools are included in my PATH environment variable.
The fact that I succesfully passed the tests for the autotool versions
doesn't mean that the script managed to find them ?
Thomas
The fact that I managed
chan at mcs.anl.gov a écrit :
> The error message indicated that autoconf couldn't be found
> when test/mpi/configure.in was processed.  If autoconf wasn't
> really there, the abort and error message should have happened earlier!
> Did you set any environment variable to tell maint/updatefiles
> where autotools are located ?  i.e. autoconf, libtool and automake..
> A.Chan
> ----- "Thomas Ropars" <tropars at irisa.fr> wrote:
>> Hi,
>> I've just checkout mpich2 svn trunk. Following the process described
>> here,
>> http://wiki.mcs.anl.gov/mpich2/index.php/Getting_And_Building_MPICH2,
>> I'm trying to run
>> ./maint/updatefiles
>> But I get the following error message:
>> Rebuilding all configure script because of missing confdbtimestamp
>> Found ./test/mpi/configure.in; executing make configure target
>> (cd . && autoheader -I ../../confdb && \
>> 	 -I ../../confdb )
>> /bin/sh: -I: not found
>> make: *** [configure] Erreur 127
>> See /local/tempo/mpich/mpich2/test/mpi/mf.tmp for Makefile that
>> failed
>> Error! Could not build configure in ./test/mpi with make configure
>> PANIC: Could not make configure from configure.in
>> In directory ./test/mpi
>> Regards,
>> Thomas
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
