[mpich-discuss] problem compiling svn trunk
    chan at mcs.anl.gov
    chan at mcs.anl.gov
    Mon Mar  8 13:06:26 CST 2010
The error message indicated that autoconf couldn't be found
when test/mpi/configure.in was processed.  If autoconf wasn't
really there, the abort and error message should have happened earlier!
Did you set any environment variable to tell maint/updatefiles
where autotools are located ?  i.e. autoconf, libtool and automake..
A.Chan
----- "Thomas Ropars" <tropars at irisa.fr> wrote:
> Hi,
> I've just checkout mpich2 svn trunk. Following the process described
> here,
> http://wiki.mcs.anl.gov/mpich2/index.php/Getting_And_Building_MPICH2,
> I'm trying to run
> ./maint/updatefiles
> But I get the following error message:
> Rebuilding all configure script because of missing confdbtimestamp
> Found ./test/mpi/configure.in; executing make configure target
> (cd . && autoheader -I ../../confdb && \
> 	 -I ../../confdb )
> /bin/sh: -I: not found
> make: *** [configure] Erreur 127
> See /local/tempo/mpich/mpich2/test/mpi/mf.tmp for Makefile that
> failed
> Error! Could not build configure in ./test/mpi with make configure
> PANIC: Could not make configure from configure.in
> In directory ./test/mpi
> Regards,
> Thomas
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
