[mpich-discuss] mpiexec - specifying list of hosts in	command line without file
    Yauheni Zelenko
    zelenko at cadence.com
    Thu Jun 17 19:50:10 CDT 2010
Great!
Thank you for help, Pavan!
It's also may be useful to specify number of instances, like in host file (i.e. host:number).
Eugene.
From: mpich-discuss-bounces at mcs.anl.gov [mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Pavan Balaji [balaji at mcs.anl.gov]
Sent: Thursday, June 17, 2010 5:32 PM
Subject: Re: [mpich-discuss] mpiexec - specifying list of hosts in      command line without file
Never mind the ticket -- it was simple enough that I went ahead and
added it to trunk in r6812 (usage is "-hosts foo,bar"). You can download
a nightly tarball if you want to try it out (make sure to use >= r6812):
http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/nightly/hydra
  -- Pavan
On 06/17/2010 07:21 PM, Yauheni Zelenko wrote:
> Hi!
> I think will be great if somebody else will add new ticket.
> Error message I got:
>  Trac detected an internal error:
> OperationalError: near "s": syntax error
> Eugene.
> Sent: Thursday, June 17, 2010 4:58 PM
> Hi,
> Yes, that's a good idea. What error did you have when you were filing a
> bug report? It'll be good to get this into the system, so we don't lose
> track of it.
>   -- Pavan
> On 06/17/2010 06:44 PM, Yauheni Zelenko wrote:
>> Hi!
>> Just grep Hydra source code (1.3a) and it doen't have such command line parameter (only -f) and didn't list it in common command line parameters in usage.
>> Eugene.
>> From: mpich-discuss-bounces at mcs.anl.gov [mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Reuti [reuti at staff.uni-marburg.de]
>> Sent: Thursday, June 17, 2010 4:38 PM
>> Hi,
>> Am 18.06.2010 um 00:10 schrieb Yauheni Zelenko:
>>> I think will be good idea to introduce command line parameter for
>>> mpiexec for specifying list of hosts directly in command line.
>>> It's handy for quick experiments. Also will be useful in farm
>>> environment (like Platform LSF) where host are listed in environment
>>> variable.
>> AFAICS there exists alread the option -host to mpiexec (man mpiexec).
>> It will just need some preprocessing to convert an environment
>> variable in the proper format:
>> http://rc.partners.org/node/232
>> -- Reuti
>> mpich-discuss mailing list
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
Pavan Balaji
