[mpich-discuss] question
    Joe C
    thejcbejcrew at gmail.com
    Mon Jun 14 12:07:02 CDT 2010
If I instal ethernet cards into the two computers run an ethernet
cable between the two, instal the MPICH2 software on both computers,
and then create a direct connection network between the two, using
control panel(having one computer the host and the other the guest),
then the two computers would work as one in processing and memory
power?
Thanks again,
Bernie
On 6/14/10, Rob Ross <rross at mcs.anl.gov> wrote:
> Yeah you could use PPP or SLIP or something over the link, but
> Ethernet would be much easier to deal with, unless you're just wanting
> to do a retro communication project.
> Rob
> On Jun 14, 2010, at 2:38 AM, Nicolas Rosner wrote:
>> I think you'd need at least, say, a tcp/ip stack on top of the
>> serial wire.
>> May I ask why a serial link instead of, say, Ethernet?
>> hth,
>> N.
>> On Sun, Jun 13, 2010 at 9:28 PM, Joe C <thejcbejcrew at gmail.com> wrote:
>>> Hi,
>>> I was wondering, if I were to connect two computers together with a
>>> cable between the serial ports on the two computers and instal the
>>> MPICH2 software on them would the two computers act as one in
>>> processing and memory?
>>> Thank you very much,
>>> Bernie Socha
>>> _______________________________________________
>>> mpich-discuss mailing list
>>> mpich-discuss at mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
