[mpich-discuss] Problems install MPICH2 on Solaris 10 i386_64
    Dave Goodell
    goodell at mcs.anl.gov
    Thu Jun  3 16:38:21 CDT 2010
Yes, it looks like "--divide" just isn't supported by the binutils version that you have, but the gcc still emits assembly that uses "/" as a constant divide operator.  The tool chain is just broken.
Unfortunately I don't have much specific Solaris knowledge that I can contribute.  I would probably look into one of the packaging systems like OpenCSW:
http://en.wikipedia.org/wiki/OpenCSW
http://www.opencsw.org/
http://www.opencsw.org/packages/gcc4core
You could also ask your coworkers if they have any Solaris experience.
-Dave
On Jun 3, 2010 , at 4:15 PM CDT, Timothy LeBlanc wrote:
> Hi Dave
> Thanks again for all the help. I have listed your request below. As I mentioned before I'm not a Solaris guy by trade and wanted to build out a test VMimage for a project I will be delivering on Solaris. I downloaded the latest Solaris installer from Oracle/Sun and the latest Companion cd and installed the whole Companion cd. Do I need something else? Could you point me in a direction to get a compiler tool chain?
> Thanks for the help.
> Tim
> bash-3.00$  /usr/sfw/bin/gas --version
> GNU assembler 2.15
> Copyright 2002 Free Software Foundation, Inc.
> This program is free software; you may redistribute it under the terms of
> the GNU General Public License.  This program has absolutely no warranty.
> This assembler was configured for a target of `i386-pc-solaris2.10'.
> bash-3.00$ /usr/sfw/bin/gas --help
> Usage: /usr/sfw/bin/gas [option...] [asmfile...]
> Options:
>   -a[sub-option...]       turn on listings
>                           Sub-options [default hls]:
>                           c      omit false conditionals
>                           d      omit debugging directives
>                           h      include high-level source
>                           l      include assembly
>                           m      include macro expansions
>                           n      omit forms processing
>                           s      include symbols
>                           =FILE  list to FILE (must be last sub-option)
>   -D                      produce assembler debugging messages
>   --defsym SYM=VAL        define symbol SYM to given value
>   --execstack             require executable stack for this object
>   --noexecstack           don't require executable stack for this object
>   -f                      skip whitespace and comment preprocessing
>   --gstabs                generate stabs debugging information
>   --gstabs+               generate stabs debug info with GNU extensions
>   --gdwarf2               generate DWARF2 debugging information
>   --help                  show this message and exit
>   --target-help           show target specific options
>   -I DIR                  add DIR to search list for .include directives
>   -J                      don't warn about signed overflow
>   -K                      warn when differences altered for long displacements
>   -L,--keep-locals        keep local symbols (e.g. starting with `L')
>   -M,--mri                assemble in MRI compatibility mode
>   --MD FILE               write dependency information in FILE (default none)
>   -nocpp                  ignored
>   -o OBJFILE              name the object-file output OBJFILE (default a.out)
>   -R                      fold data section into text section
>   --statistics            print various measured statistics from execution
>   --strip-local-absolute  strip local absolute symbols
>   --traditional-format    Use same format as native assembler when possible
>   --version               print assembler version number and exit
>   -W  --no-warn           suppress warnings
>   --warn                  don't suppress warnings
>   --fatal-warnings        treat warnings as errors
>   --itbl INSTTBL          extend instruction set to include instructions
>                           matching the specifications defined in file INSTTBL
>   -w                      ignored
>   -X                      ignored
>   -Z                      generate object file even after errors
>   --listing-lhs-width     set the width in words of the output data column of
>                           the listing
>   --listing-lhs-width2    set the width in words of the continuation lines
>                           of the output data column; ignored if smaller than
>                           the width of the first line
>   --listing-rhs-width     set the max width in characters of the lines from
>                           the source file
>   --listing-cont-lines    set the maximum number of continuation lines used
>                           for the output data column of the listing
>   -Q                      ignored
>   -V                      print assembler version number
>   -k                      ignored
>   -n                      Do not optimize code alignment
>   -q                      quieten some warnings
>   -s                      ignored
> Report bugs to bug-binutils at gnu.org
> On Thu, Jun 3, 2010 at 4:50 PM, Dave Goodell <goodell at mcs.anl.gov> wrote:
> So your assembler seems to not tolerate "/" for literal expressions, but doesn't understand "--divide".  Would you also please send me the output of:
> According to http://sourceware.org/bugzilla/show_bug.cgi?id=4572 the "/" problem was introduced somewhere between binutils-2.13 to 2.15 versions, but it's not obvious to me when the "--divide" option was added.  Your version may fall into a gap between the two.
> It looks like you have a non-functional compiler tool chain on your Solaris box.  You should consider installing an updated one.
> -Dave
> On Jun 3, 2010 , at 2:34 PM CDT, Timothy LeBlanc wrote:
> > Hi Dave
> > here it is.
> > Tim
> > On Thu, Jun 3, 2010 at 3:33 PM, Dave Goodell <goodell at mcs.anl.gov> wrote:
> > No.  In that case, please send the config.log instead.
> > -Dave
> > On Jun 3, 2010 , at 2:31 PM CDT, Timothy LeBlanc wrote:
> > > Hi Dave
> > > When I run the command
> > > /configure CFLAGS=-Wa,--divide --prefix=/usr/local/bin/mpich2-install 2>&1 | tee c.txt
> > > The display only shows about 20 lines before failing they are:
> > > Configuring MPICH2 version 1.2.1p1 with  'CFLAGS=-Wa,--divide' '--prefix=/usr/local/bin/mpich2-install'
> > > Running on system: SunOS mars 5.10 Generic_141445-09 i86pc i386 i86pc
> > > Executing mpich2prereq in /work/mpich2/mpich2-1.2.1p1/src/mpid/ch3 with
> > > Executing mpich2prereq in /work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis
> > > sourcing /work/mpich2/mpich2-1.2.1p1/src/pm/mpd/mpich2prereq
> > > sourcing /work/mpich2/mpich2-1.2.1p1/src/pm/hydra/mpich2prereq
> > > sourcing /work/mpich2/mpich2-1.2.1p1/src/pm/gforker/mpich2prereq
> > > sourcing /work/mpich2/mpich2-1.2.1p1/src/pm/mpd/setup_pm
> > > checking for gcc... gcc
> > > checking for C compiler default output file name...
> > > configure: error: in `/work/mpich2/mpich2-1.2.1p1':
> > > configure: error: C compiler cannot create executables
> > > See `config.log' for more details.
> > > Do you still want me to run make and send you the m.txt file?
> > > Tim
> > > On Thu, Jun 3, 2010 at 2:40 PM, Dave Goodell <goodell at mcs.anl.gov> wrote:
> > > On Jun 3, 2010 , at 1:29 PM CDT, Timothy LeBlanc wrote:
> > > > --divide does not seem to be an acceptable parameter . When I type in configure --help it is not listed and it fails when I try using it.
> > > > So I followed up with running:
> > > > ./configure CFLAGS=-Wa, --prefix=/usr/local/bin/mpich2-install 2>&1 | tee c.txt
> > > This is the not the format you should use.  The whole "-Wa,--divide" matters.  So the command should look like the first one you listed:
> > >  ./configure CFLAGS=-Wa,--divide --prefix=/usr/local/bin/mpich2-install 2>&1 | tee c.txt
> > > > And this fails in the same way as I explained. Seems to configure ok but then the make fails.
> > > Please send us the m.txt from the make command when using the above configuration:
> > >  make V=1 2>&1 | tee m.txt
> > > I'm surprised that this didn't work for you and I'd like to see what's really going on here.
> > > -Dave
> > > _______________________________________________
> > > mpich-discuss mailing list
> > > mpich-discuss at mcs.anl.gov
> > > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> > > The information contained in this E-mail message is privileged, confidential, and may be protected from disclosure; please be aware that any other use, printing, copying, disclosure or dissemination
> > > of this communication may be subject to legal restriction or sanction. If you think that you have received this E-mail message in error, please reply to the sender and delete it from your computer. Thank you.
> > <config.log>_______________________________________________
