[mpich-discuss] Problems install MPICH2 on Solaris 10 i386_64
    Timothy LeBlanc
    timothy.leblanc at gmail.com
    Thu Jun  3 16:15:46 CDT 2010
Hi Dave
Thanks again for all the help. I have listed your request below. As I
mentioned before I'm not a Solaris guy by trade and wanted to build out a
test VMimage for a project I will be delivering on Solaris. I downloaded the
latest Solaris installer from Oracle/Sun and the latest Companion cd and
installed the whole Companion cd. Do I need something else? Could you point
me in a direction to get a compiler tool chain?
Thanks for the help.
Tim
bash-3.00$  /usr/sfw/bin/gas --version
GNU assembler 2.15
Copyright 2002 Free Software Foundation, Inc.
This program is free software; you may redistribute it under the terms of
the GNU General Public License.  This program has absolutely no warranty.
This assembler was configured for a target of `i386-pc-solaris2.10'.
bash-3.00$ /usr/sfw/bin/gas --help
Usage: /usr/sfw/bin/gas [option...] [asmfile...]
Options:
  -a[sub-option...]       turn on listings
                          Sub-options [default hls]:
                          c      omit false conditionals
                          d      omit debugging directives
                          h      include high-level source
                          l      include assembly
                          m      include macro expansions
                          n      omit forms processing
                          s      include symbols
                          =FILE  list to FILE (must be last sub-option)
  -D                      produce assembler debugging messages
  --defsym SYM=VAL        define symbol SYM to given value
  --execstack             require executable stack for this object
  --noexecstack           don't require executable stack for this object
  -f                      skip whitespace and comment preprocessing
  --gstabs                generate stabs debugging information
  --gstabs+               generate stabs debug info with GNU extensions
  --gdwarf2               generate DWARF2 debugging information
  --help                  show this message and exit
  --target-help           show target specific options
  -I DIR                  add DIR to search list for .include directives
  -J                      don't warn about signed overflow
  -K                      warn when differences altered for long
displacements
  -L,--keep-locals        keep local symbols (e.g. starting with `L')
  -M,--mri                assemble in MRI compatibility mode
  --MD FILE               write dependency information in FILE (default
none)
  -nocpp                  ignored
  -o OBJFILE              name the object-file output OBJFILE (default
a.out)
  -R                      fold data section into text section
  --statistics            print various measured statistics from execution
  --strip-local-absolute  strip local absolute symbols
  --traditional-format    Use same format as native assembler when possible
  --version               print assembler version number and exit
  -W  --no-warn           suppress warnings
  --warn                  don't suppress warnings
  --fatal-warnings        treat warnings as errors
  --itbl INSTTBL          extend instruction set to include instructions
                          matching the specifications defined in file
INSTTBL
  -w                      ignored
  -X                      ignored
  -Z                      generate object file even after errors
  --listing-lhs-width     set the width in words of the output data column
of
                          the listing
  --listing-lhs-width2    set the width in words of the continuation lines
                          of the output data column; ignored if smaller than
                          the width of the first line
  --listing-rhs-width     set the max width in characters of the lines from
                          the source file
  --listing-cont-lines    set the maximum number of continuation lines used
                          for the output data column of the listing
  -Q                      ignored
  -V                      print assembler version number
  -k                      ignored
  -n                      Do not optimize code alignment
  -q                      quieten some warnings
  -s                      ignored
Report bugs to bug-binutils at gnu.org
On Thu, Jun 3, 2010 at 4:50 PM, Dave Goodell <goodell at mcs.anl.gov> wrote:
> So your assembler seems to not tolerate "/" for literal expressions, but
> doesn't understand "--divide".  Would you also please send me the output of:
> According to http://sourceware.org/bugzilla/show_bug.cgi?id=4572 the "/"
> problem was introduced somewhere between binutils-2.13 to 2.15 versions, but
> it's not obvious to me when the "--divide" option was added.  Your version
> may fall into a gap between the two.
> It looks like you have a non-functional compiler tool chain on your Solaris
> box.  You should consider installing an updated one.
> -Dave
> On Jun 3, 2010 , at 2:34 PM CDT, Timothy LeBlanc wrote:
> > Hi Dave
> > here it is.
> > Tim
> > On Thu, Jun 3, 2010 at 3:33 PM, Dave Goodell <goodell at mcs.anl.gov>
> wrote:
> > No.  In that case, please send the config.log instead.
> > -Dave
> > On Jun 3, 2010 , at 2:31 PM CDT, Timothy LeBlanc wrote:
> > > Hi Dave
> > > When I run the command
> > > /configure CFLAGS=-Wa,--divide --prefix=/usr/local/bin/mpich2-install
> 2>&1 | tee c.txt
> > > The display only shows about 20 lines before failing they are:
> > > Configuring MPICH2 version 1.2.1p1 with  'CFLAGS=-Wa,--divide'
> '--prefix=/usr/local/bin/mpich2-install'
> > > Running on system: SunOS mars 5.10 Generic_141445-09 i86pc i386 i86pc
> > > Executing mpich2prereq in /work/mpich2/mpich2-1.2.1p1/src/mpid/ch3 with
> /work/mpich2/mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis
> > > sourcing /work/mpich2/mpich2-1.2.1p1/src/pm/mpd/mpich2prereq
> > > sourcing /work/mpich2/mpich2-1.2.1p1/src/pm/hydra/mpich2prereq
> > > sourcing /work/mpich2/mpich2-1.2.1p1/src/pm/gforker/mpich2prereq
> > > sourcing /work/mpich2/mpich2-1.2.1p1/src/pm/mpd/setup_pm
> > > checking for gcc... gcc
> > > checking for C compiler default output file name...
> > > configure: error: in `/work/mpich2/mpich2-1.2.1p1':
> > > configure: error: C compiler cannot create executables
> > > See `config.log' for more details.
> > > Do you still want me to run make and send you the m.txt file?
> > > Tim
> > > On Thu, Jun 3, 2010 at 2:40 PM, Dave Goodell <goodell at mcs.anl.gov>
> wrote:
> > > On Jun 3, 2010 , at 1:29 PM CDT, Timothy LeBlanc wrote:
> > > > --divide does not seem to be an acceptable parameter . When I type in
> configure --help it is not listed and it fails when I try using it.
> > > > So I followed up with running:
> > > > ./configure CFLAGS=-Wa, --prefix=/usr/local/bin/mpich2-install 2>&1 |
> tee c.txt
> > > This is the not the format you should use.  The whole "-Wa,--divide"
> matters.  So the command should look like the first one you listed:
> > >  ./configure CFLAGS=-Wa,--divide --prefix=/usr/local/bin/mpich2-install
> 2>&1 | tee c.txt
> > > > And this fails in the same way as I explained. Seems to configure ok
> but then the make fails.
> > > Please send us the m.txt from the make command when using the above
> configuration:
> > >  make V=1 2>&1 | tee m.txt
> > > I'm surprised that this didn't work for you and I'd like to see what's
> really going on here.
> > > -Dave
> > > _______________________________________________
> > > mpich-discuss mailing list
> > > mpich-discuss at mcs.anl.gov
> > > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> > > The information contained in this E-mail message is privileged,
> confidential, and may be protected from disclosure; please be aware that any
> other use, printing, copying, disclosure or dissemination
> > > of this communication may be subject to legal restriction or sanction.
> If you think that you have received this E-mail message in error, please
> reply to the sender and delete it from your computer. Thank you.
> > of this communication may be subject to legal restriction or sanction. If
> you think that you have received this E-mail message in error, please reply
> > <config.log>_______________________________________________
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100603/48ce929c/attachment.htm>
