[mpich-discuss] Fix for Hydra LSF resources query
Yauheni Zelenko
zelenko at cadence.com
Fri Jul 30 20:02:31 CDT 2010
Hi!
I want to propose fix for HYDT_bscd_lsf_query_node_list(). Currently tokenizer operates directly on environment and corrupt it (application gets truncated LSB_MCPU_HOSTS). So it's necessary to create copy of environment and work with it.
I suggest next implementation (based on r6885):
HYD_status HYDT_bscd_lsf_query_node_list(struct HYD_node **node_list)
char *hosts;
HYD_status status = HYD_SUCCESS;
HYDU_FUNC_ENTER();
if (MPL_env2str("LSB_MCPU_HOSTS", (const char **) &hosts) == 0)
hosts = NULL;
if (hosts == NULL) {
*node_list = NULL;
HYDU_ERR_SETANDJUMP(status, HYD_INTERNAL_ERROR, "No LSF node list found\n");
else {
char* hosts_copy = HYDU_strdup(hosts);
char* hostname = strtok(hosts_copy, " ");
while (1) {
char* num_procs_str;
int num_procs;
if (hostname == NULL)
break;
/* the even fields in the list should be the number of
* cores */
num_procs_str = strtok(NULL, " ");
HYDU_ASSERT(num_procs_str, status);
num_procs = atoi(num_procs_str);
status = HYDU_add_to_node_list(hostname, num_procs, node_list);
HYDU_ERR_POP(status, "unable to add to node list\n");
hostname = strtok(NULL, " ");
HYDU_free(hosts_copy);
fn_exit:
HYDU_FUNC_EXIT();
return status;
fn_fail:
goto fn_exit;
Please review it and include to Hydra code.
Eugene.
