[mpich-discuss] my mpich2 can only run cpi...
Jayesh Krishna
jayesh at mcs.anl.gov
Fri Jul 30 10:45:30 CDT 2010
Did you recompile your code (on the same machine) after installing MPICH2 ? Can you send the source code of your hello world program ?
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Thursday, July 29, 2010 10:12:46 PM GMT -06:00 US/Canada Central
Subject: Re: [mpich-discuss] my mpich2 can only run cpi...
Hello,
I select "Run in a separate window" it just pop a black window and hang on(not correctly run)~ I have to press ctrl+c to abort it
the code can run on my xp machine correctly but not on my notebook
and i try "smpd -d" in commend line mode , there're some error message: ERROR:error binding socket to given port <10048>
ERROR:error creating listen sock
ERROR:SMPDU_Sock_listen failed,
socket error:ERROR=10048
How can I fix that problem?please help me~
Thanks very much
2010/7/29 Jayesh Krishna < jayesh at mcs.anl.gov >
Try selecting "Run in a separate window" (in wmpiexec) and see if it works.
Jayesh
Sent: Thursday, July 29, 2010 9:42:14 AM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] my mpich2 can only run cpi...
Hello ,
I have installed MPICH2 on my 32-bit Windows 7 dual core Hp notebook,and everything seems be alright before I run my first hello_mpi.exe...
I can run cpi example sucessfully,but when I put my hello_mpi.exe (produced by VS2008 c++ and it could run on other machines) into "public document"
and using GUI mpiexec to run it;it just pops the black window and do nothing...
there's the hello_mpi.exe process in process manager but it doesn't run correctly...
Thanks a lot!!! appreciate!!!
mpich-discuss mailing list
願天常生好人,人常做好事.........
