[mpich-discuss] MPICH2 problem
Dave Goodell
goodell at mcs.anl.gov
Wed Jul 28 12:52:30 CDT 2010
It looks more like a linking problem to me. Make sure you are using the mpicc/mpicxx/mpif77/mpif90 wrappers to compile your program, they should include a "-lpthread" on the link line. If that's not working, try inserting "-lpthread" manually on the link line.
-Dave
On Jul 28, 2010, at 12:46 PM CDT, Ivan Pulido wrote:
> On Wed, Jul 28, 2010 at 12:19 PM, Grzegorz Dwornicki <gd1100 at gmail.com> wrote:
> Ive reinstaled the distribution to clean debian squeeze. Now when im compiling im getting:
> /usr/lib/libmpich.a(info_getnth.o): In function `MPI_Info_get_nthkey':
> (.text+0x2f9): undefined reference to `pthread_getspecific'
> (.text+0x32a): undefined reference to `pthread_setspecific'
> /usr/lib/libmpich.a(info_getvallen.o): In function `MPI_Info_get_valuelen':
> (.text+0x2e): undefined reference to `pthread_getspecific'
> (.text+0x368): undefined reference to `pthread_setspecific'
> (.text+0x381): undefined reference to `pthread_getspecific'
> (.text+0x3b2): undefined reference to `pthread_setspecific'
> Ive made a symlink from /usr/bin/gfortran to /ust/bin/g77. It worked before but not it doesn work. Any ideas? This errors are slim part of full output but they are are nearly the same (same kind but diferent sections). I have only 1 idea but it might blow everything up. The idea is to try using gfortran from lenny. But it wil require to change a lot of libs and some programs including gcc it self.
> Not sure if this is the problem, forgive me if it isn't. But those pthread functions are declared in pthread.h (make sure you have it, usually it's in /usr/include/pthread.h). On Debian you should accomplish this by installing "libc6-dev" package. Hope this helps.
> Gregory
> 2010/7/21 Grzegorz Dwornicki <gd1100 at gmail.com>
> yea ive typed apt-get remove mpich-bin. And then ive used "make clean" and "make arch=Linux_PII_CBLAS". Hmm i can doo even more - If some liblaries are messing things up I will reinstall distribution to be sure. I'll update this topic on monday :)
> Gregory.
> 2010/7/21 Pavan Balaji <balaji at mcs.anl.gov>
> > [0] Aborting program !
> > [0] Aborting program!
> > p0_3435: p4_error: : 9039
> Well, P4 is used in MPICH-1, not MPICH-2. So, you cannot get the same error if you are not using MPICH-1 :-).
> Did you recompile with MPICH2?
> -- Pavan
> On 07/21/2010 11:16 AM, Grzegorz Dwornicki wrote:
> Ive remove mpich-bin package and recompiled the hpl linpack. But im geting the same error :(
> 2010/7/19 Grzegorz Dwornicki <gd1100 at gmail.com <mailto:gd1100 at gmail.com>>
> Thx you both for such fast reply. Ill try your advices on wednesday
> and report results.
> Gregory.
> 2010/7/19 Dave Goodell <goodell at mcs.anl.gov
> <mailto:goodell at mcs.anl.gov>>
> On Jul 19, 2010, at 11:51 AM CDT, Grzegorz Dwornicki wrote:
> > If im writing double message on list pls let me know.
> > Im writing a graduating paper on my university about MPICH
> and im having some trouble launching programs. For example I
> need to run perfomance tests on cluster, to determine it max.
> potencial. To do this Im using hpl linpack from
> http://www.netlib.org/benchmark/hpl/. Compilation goes without
> any errors but when I type f.e:
> > mpirun -np 4 ./xhpl
> > Im getting output like this:
> > 0 - <NO ERROR MESSAGE> : Could not convert index 1140850688
> into a pointer
> > The index may be an incorrect argument.
> You have somehow mixed MPICH2's mpi.h or mpif.h headers with
> the library from MPICH:
> % perl -e 'printf("%#x\n",1140850688);'
> 0x44000000
> % grep 0x44000000 mpi.h
> #define MPI_COMM_WORLD ((MPI_Comm)0x44000000)
> As Pavan suggested, uninstall MPICH and make sure that MPICH2 is
> fully installed. Also, make sure that you recompile your
> application once the MPICH installation is removed. Make sure
> to use the compiler wrappers provided by MPICH2 (mpicc, mpif90,
> etc) when building your application.
> -Dave
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov <mailto:mpich-discuss at mcs.anl.gov>
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
> Ivan Pulido
> Estudiante de Física
> Universidad Nacional de Colombia
