[mpich-discuss] MPICH2 problem
Ivan Pulido mefistofeles87 at gmail.com
Wed Jul 28 12:46:01 CDT 2010
On Wed, Jul 28, 2010 at 12:19 PM, Grzegorz Dwornicki <gd1100 at gmail.com>wrote:
> Ive reinstaled the distribution to clean debian squeeze. Now when im
> compiling im getting:
> /usr/lib/libmpich.a(info_getnth.o): In function `MPI_Info_get_nthkey':
> (.text+0x2f9): undefined reference to `pthread_getspecific'
> (.text+0x32a): undefined reference to `pthread_setspecific'
> /usr/lib/libmpich.a(info_getvallen.o): In function `MPI_Info_get_valuelen':
> (.text+0x2e): undefined reference to `pthread_getspecific'
> (.text+0x368): undefined reference to `pthread_setspecific'
> (.text+0x381): undefined reference to `pthread_getspecific'
> (.text+0x3b2): undefined reference to `pthread_setspecific'
> Ive made a symlink from /usr/bin/gfortran to /ust/bin/g77. It worked before
> but not it doesn work. Any ideas? This errors are slim part of full output
> but they are are nearly the same (same kind but diferent sections).  I have
> only 1 idea but it might blow everything up. The idea is to try using
> gfortran from lenny. But it wil require to change a lot of libs and some
> programs including gcc it self.
Not sure if this is the problem, forgive me if it isn't. But those pthread
functions are declared in pthread.h (make sure you have it, usually it's in
/usr/include/pthread.h). On Debian you should accomplish this by installing
"libc6-dev" package. Hope this helps.
> Gregory
> 2010/7/21 Grzegorz Dwornicki <gd1100 at gmail.com>
>> yea ive typed apt-get remove mpich-bin. And then ive used "make clean" and
>> "make arch=Linux_PII_CBLAS". Hmm i can doo even more - If some liblaries are
>> messing things up I will reinstall distribution to be sure. I'll update this
>> topic on monday :)
>> Gregory.
>> 2010/7/21 Pavan Balaji <balaji at mcs.anl.gov>
>>> > [0]  Aborting program !
>>> > [0] Aborting program!
>>> > p0_3435:  p4_error: : 9039
>>> Well, P4 is used in MPICH-1, not MPICH-2. So, you cannot get the same
>>> error if you are not using MPICH-1 :-).
>>> Did you recompile with MPICH2?
>>>  -- Pavan
>>> On 07/21/2010 11:16 AM, Grzegorz Dwornicki wrote:
>>>> Ive remove mpich-bin package and recompiled the hpl linpack. But im
>>>> geting the same error :(
>>>> 2010/7/19 Grzegorz Dwornicki <gd1100 at gmail.com <mailto:gd1100 at gmail.com
>>>>    Thx you both for such fast reply. Ill try your advices on wednesday
>>>>    and report results.
>>>>    Gregory.
>>>>    2010/7/19 Dave Goodell <goodell at mcs.anl.gov
>>>>    <mailto:goodell at mcs.anl.gov>>
>>>>        On Jul 19, 2010, at 11:51 AM CDT, Grzegorz Dwornicki wrote:
>>>>         > If im writing double message on list pls let me know.
>>>>         > Im writing a graduating paper on my university about MPICH
>>>>        and im having some trouble launching programs. For example I
>>>>        need to run perfomance tests on cluster, to determine it max.
>>>>        potencial. To do this Im using hpl linpack from
>>>>        http://www.netlib.org/benchmark/hpl/. Compilation goes without
>>>>        any errors but when I type f.e:
>>>>         > mpirun -np 4 ./xhpl
>>>>         > Im getting output like this:
>>>>         > 0 - <NO ERROR MESSAGE> : Could not convert index 1140850688
>>>>        into a pointer
>>>>         > The index may be an incorrect argument.
>>>>        You have somehow mixed MPICH2's mpi.h or mpif.h headers  with
>>>>        the library from MPICH:
>>>>        % perl -e 'printf("%#x\n",1140850688);'
>>>>        0x44000000
>>>>        % grep 0x44000000 mpi.h
>>>>        #define MPI_COMM_WORLD ((MPI_Comm)0x44000000)
>>>>        As Pavan suggested, uninstall MPICH and make sure that MPICH2 is
>>>>        fully installed.  Also, make sure that you recompile your
>>>>        application once the MPICH installation is removed.  Make sure
>>>>        to use the compiler wrappers provided by MPICH2 (mpicc, mpif90,
>>>>        etc) when building your application.
>>>>        -Dave
>>>>        _______________________________________________
>>>>        mpich-discuss mailing list
>>>>        mpich-discuss at mcs.anl.gov <mailto:mpich-discuss at mcs.anl.gov>
>>>>        https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>>> Pavan Balaji
>>> http://www.mcs.anl.gov/~balaji <http://www.mcs.anl.gov/%7Ebalaji>
Ivan Pulido
Estudiante de Física
Universidad Nacional de Colombia
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100728/c568d4cf/attachment.htm>
