[mpich-discuss] machinefile error
Pavan Balaji balaji at mcs.anl.gov
Tue Jul 20 10:11:52 CDT 2010
The error you are reporting doesn't seem to be coming from Hydra's
mpiexec. Also, is this on windows (since your executable is called cpi.exe)?
On windows the default process manager is SMPD, and you'll need to
follow its instructions from the user guide. On UNIX, the default
process manager is MPD for up to MPICH2-1.2.1p1. For MPICH2-1.3, we are
changing the default to Hydra.
  -- Pavan
On 07/20/2010 07:13 AM, SULLIVAN David (AREVA) wrote:
> Hello all,
> I am having some issues executing a program through mpiexec. I can run
> locally on a 4-core processor with no problem using the -host switch.
> When I define a machinefile I get the following error:
> " Too few entries in machinefile"
> This error is not covered in the manual or FAQs and Google has been of
> little assistance. I have tried the following to no avail:
> 1. An old entry in the list-serve archives recommended a series of
> commands like the following  mpiexec -machinefile mf1.txt -n 1 cpi.exe :
> -machinefile mf2.txt -n 2   This yields the same error for too few entries.
> 2. The wiki recommends two course of actions :
>     a) using the -f switch instead of the -machinefile    This gets an
> error that -f needs to be used on its own
>     b) setting the HYDRA_HOST_FILE variable with no need for any
> additional switch. This just runs all processes on the local machine
> I am attempting to run a parallel program written by Los Alamos across
> three nodes, each with 4 cores per node. Any assistance would be greatly
> appreciated
> David Sullivan
> *AREVA NP INC*
> 400 Donald Lynch Boulevard
> Marlborough, MA, 01752
> Phone: (508) 573-6721
> Fax: (434) 382-5597
> David.Sullivan at AREVA.com <mailto:David.Sullivan at AREVA.com>
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
Pavan Balaji
http://www.mcs.anl.gov/~balaji
