[mpich-discuss] Credentials Rejected - Windows Vista/7 Home Premium
Leonard E Schwer Len at Schwer.net
Mon Jul 19 01:23:00 CDT 2010
Thanks Jayesh.
Some progress with -validate but no cigar:
C:\Windows\system32>mpiexec -remove
Account and password removed from the Registry.
C:\Windows\system32>mpiexec -register
account (domain\user) [SECS8\Schwer]: Schwer
password:
confirm password:
Password encrypted into the Registry.
C:\Windows\system32>mpiexec -validate
SUCCESS
C:\Windows\system32>mpiexec -n 2 hostname
Credentials for Schwer rejected connecting to SECS8
Aborting: Unable to connect to SECS8
	--len
-----Original Message-----
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Jayesh Krishna
Sent: Sunday, July 18, 2010 7:55 PM
To: Len at schwer.net
Cc: mpich-discuss at mcs.anl.gov
Subject: Re: [mpich-discuss] Credentials Rejected - Windows Vista/7 Home
Premium
 Try just registering "Schwer" (instead of "SECS8\Schwer") and see if it
works ("validate" should pass).
Jayesh
----- Original Message -----
To: jayesh at mcs.anl.gov
Sent: Friday, July 16, 2010 5:04:05 PM GMT -06:00 US/Canada Central
Subject: RE: [mpich-discuss] Credentials Rejected - Windows Vista/7 Home
Premium
Thanks again Jayesh for the reply.
I attempted your suggestion to -validate and this failed:
DeleteCurrentPasswordRegistryEntry:RegDeleteValue(password) failed, error: 6
ERROR: Unable to remove the encrypted password.
password:
confirm password:
FAIL
C:\Windows\system32>hostname
SECS8
I *think* SECS8 is both the hostname and computer name, but is at least the
hostname.
	--len
From: jayesh at mcs.anl.gov [mailto:jayesh at mcs.anl.gov]
Sent: Thursday, July 15, 2010 4:29 PM
To: Len at Schwer.net
Premium
 After registering your username try validating the username/password with
the "-validate" option and provide us with the results.
 Is "SECS8" the domain name or the computer name (Type "hostname" at the
command prompt) ?
Jayesh
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>, mpich-discuss at mcs.anl.gov
Sent: Thursday, July 15, 2010 3:21:11 PM GMT -06:00 US/Canada Central
Premium
Thanks Jayesh for the response.
I have installed the 64-bit version of MPICH2 on the Windows Vista & 7
boxes.
Yes "Schwer" is a user on domain "SECS8," with admin privileges.
I believe I demonstrated in my original email the your suggestions, re:
-remove & -register. Also, accepting the offered domain/username via hitting
a return and then supplying the password.
Thanks again for your offered suggestions.		--len
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: Tuesday, July 13, 2010 5:43 PM
To: Len at Schwer.net; mpich-discuss at mcs.anl.gov
Premium
 If you are installing MPICH2 on a 64-bit machine we recommend that you
install the 64-bit version of MPICH2
(http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downl
oads). Try if it works.
 From the error message, It looks like the username/password combination is
not valid.
 Is "Schwer" a domain user (on domain SECS8)? Try accepting the default
username (Press Enter key when prompted for the username with the
"-register" option) and provide the password when prompted and see if it
works.
 Let us know the results.
Jayesh
Sent: Thursday, July 8, 2010 9:55:44 AM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] Credentials Rejected - Windows Vista/7 Home Premium
Hello --
I have a successful Windows XP 32 bit install of MPICH2.
I have attempted installs on two other boxes: Windows Vista and Windows 7,
both 64 bit. As far as I can tell the install went well.
My problem is getting either install to recognize my username/password.
Below is a command window session where the command window was launched
using "Run as Administrator"
password:
confirm password:
C:\Windows\system32>mpiexec -n 1 hostname
Credentials for SECS8\Schwer rejected connecting to SECS8
Any suggestions or pointers?
Thanks,	--len
Len Schwer, PhD    Schwer Engineering & Consulting Services
Len at Schwer.net              6122 Aaron Court
www.schwer.net              Windsor CA 95492
707.837.0559 (Voice)        928.833.1130 (eFAX)
707.480.8056 (Mobile)
mpich-discuss mailing list
