[mpich-discuss] Credentials Rejected - Windows Vista/7 Home Premium
Jayesh Krishna jayesh at mcs.anl.gov
Sun Jul 18 21:54:39 CDT 2010
 Try just registering "Schwer" (instead of "SECS8\Schwer") and see if it works ("validate" should pass).
Jayesh
----- Original Message -----
To: jayesh at mcs.anl.gov
Cc: mpich-discuss at mcs.anl.gov
Sent: Friday, July 16, 2010 5:04:05 PM GMT -06:00 US/Canada Central
Subject: RE: [mpich-discuss] Credentials Rejected - Windows Vista/7 Home Premium
Thanks again Jayesh for the reply.
I attempted your suggestion to -validate and this failed:
C:\Windows\system32>mpiexec -remove
DeleteCurrentPasswordRegistryEntry:RegDeleteValue(password) failed, error: 6
ERROR: Unable to remove the encrypted password.
C:\Windows\system32>mpiexec -register
account (domain\user) [SECS8\Schwer]:
password:
confirm password:
Password encrypted into the Registry.
C:\Windows\system32>mpiexec -validate
FAIL
C:\Windows\system32>hostname
SECS8
I *think* SECS8 is both the hostname and computer name, but is at least the hostname.
	--len
-----Original Message-----
From: jayesh at mcs.anl.gov [mailto:jayesh at mcs.anl.gov]
Sent: Thursday, July 15, 2010 4:29 PM
To: Len at Schwer.net
Subject: Re: [mpich-discuss] Credentials Rejected - Windows Vista/7 Home Premium
 After registering your username try validating the username/password with the "-validate" option and provide us with the results.
 Is "SECS8" the domain name or the computer name (Type "hostname" at the command prompt) ?
Jayesh
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>, mpich-discuss at mcs.anl.gov
Sent: Thursday, July 15, 2010 3:21:11 PM GMT -06:00 US/Canada Central
Thanks Jayesh for the response.
I have installed the 64-bit version of MPICH2 on the Windows Vista & 7 boxes.
Yes "Schwer" is a user on domain "SECS8," with admin privileges.
I believe I demonstrated in my original email the your suggestions, re: -remove & -register. Also, accepting the offered domain/username via hitting a return and then supplying the password.
Thanks again for your offered suggestions.		--len
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: Tuesday, July 13, 2010 5:43 PM
To: Len at Schwer.net; mpich-discuss at mcs.anl.gov
 If you are installing MPICH2 on a 64-bit machine we recommend that you install the 64-bit version of MPICH2 (http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads). Try if it works.
 From the error message, It looks like the username/password combination is not valid.
 Is "Schwer" a domain user (on domain SECS8)? Try accepting the default username (Press Enter key when prompted for the username with the "-register" option) and provide the password when prompted and see if it works.
 Let us know the results.
Jayesh
Sent: Thursday, July 8, 2010 9:55:44 AM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] Credentials Rejected - Windows Vista/7 Home Premium
Hello --
I have a successful Windows XP 32 bit install of MPICH2.
I have attempted installs on two other boxes: Windows Vista and Windows 7,
both 64 bit. As far as I can tell the install went well.
My problem is getting either install to recognize my username/password.
Below is a command window session where the command window was launched
using "Run as Administrator"
Account and password removed from the Registry.
password:
confirm password:
C:\Windows\system32>mpiexec -n 1 hostname
Credentials for SECS8\Schwer rejected connecting to SECS8
Aborting: Unable to connect to SECS8
Any suggestions or pointers?
Thanks,	--len
Len Schwer, PhD    Schwer Engineering & Consulting Services
Len at Schwer.net              6122 Aaron Court
www.schwer.net              Windsor CA 95492
707.837.0559 (Voice)        928.833.1130 (eFAX)
707.480.8056 (Mobile)
mpich-discuss mailing list
