[mpich-discuss] Help: MPICH for a beginner
Pavan Balaji balaji at mcs.anl.gov
Tue Jul 13 11:59:32 CDT 2010
On 07/13/2010 11:47 AM, Michele Rosso wrote:
> Thanks Pavan for your reply.
> I followed the instructions.
> At first I got mpd started, then, after I compiled my code through
> mpif90, I run the executable by using the command:
> mpiexec -np 4 ./filename
> This command works properly since I got the results I was expecting, but
> I have the feeling that it is still running the serial version of the
> code, since in the output (shell) there are only the output lines of the
> node 0. Any idea about that?
Are you sure your program is not doing something like:
if (my_rank is 0)
    print(...)
You can try some other program, maybe "ls" or "hostname":
% mpiexec -np 4 hostname
% mpiexec -np 4 ls
This should give you a separate output for each process.
  -- Pavan
Pavan Balaji
http://www.mcs.anl.gov/~balaji
