[mpich-discuss] x86 and x86_64
    Stefan Kuhne
    stefan.kuhne at dialup.fh-aachen.de
    Wed Jan 27 06:13:51 CST 2010
Matveyev Alexander schrieb:
> Thank you for you reply!
> Compiling MPICH2 in 32-bit mode isn't very good solution in my case,
> unfortunately. Could you please explain a bit more detailed what is the
> problem with sending messages between machines with different
> architecture? MPI uses it's own data types, x86 and x86_32 have the same
> byte order. I'm sorry to bother you but I really don't understand.
Normaly you export the bianries with NFs or something simular.
So you execute the same binary on all machines.
There is your Problem.
You can try to have seperate binaries on your machines.
Stefan Kuhne
Type: text/x-vcard
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100127/955537ca/attachment.vcf>
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100127/955537ca/attachment.pgp>
