[mpich-discuss] Compilation of MPCH2-1.2.1 is failing onSunSolaris 10 (Sparc)
Dave Goodell goodell at mcs.anl.gov
Mon Jan 25 16:25:48 CST 2010
I don't think it matters what shell you used to invoke "./configure".
The shell that actually interprets the command is determined by the
shebang line at the top of configure, "#! /bin/sh".  AFAIK, the
Solaris "/bin/sh" is _not_ bash or zsh, so it will not understand the
"export VAL=var" convenience syntax.
You can test this by running the following sequence of commands:
-------8<-------
/bin/sh
export FOO=" -lpthread"
-------8<-------
You should get a very similar error message to the one you received
when running configure.
The reason that you still saw the problem even after modifying
configure is that you only attempted to re-make.  You need to modify /
petara1/mpich2/mpich2-1.2.1/src/mpid/ch3/configure as I indicated
earlier, then run configure, then run make.  Changes to configure
after configure has been run won't have any effect.
-Dave
On Jan 22, 2010, at 10:40 AM, Arvind Petaru wrote:
> To add on more.....
> I was compiling on bash shell.......and i tried below commands on
> bash shell prompt and it works fine, so I don't think
> MY_EXPORTED_LIBS is creating problem here:
> lperf011-root>
> lperf011-root> VAR=abcd
> lperf011-root> echo $VAR
> abcd
> lperf011-root>
> lperf011-root> export TMPVAR="$VAR"
> lperf011-root> echo $TMPVAR
> abcd
> lperf011-root>
> lperf011-root>
> Also, there was a typo in my earlier mail for point 2, where it
> should be "--with-device=ch3:sock" instead of "--with-
> devicech3:sock", missed a "=" symbol.....
> -Arvind
> On Fri, Jan 22, 2010 at 11:29 AM, Arvind Petaru <arvindpetaru at gmail.com
> > wrote:
> Hi Dave,
>     Thanks for your suggestion.
>     I tried compiling following your suggestion and I still see the
> same errors.
> Steps I followed:
> 1> Removed everything from previous tmp build directory (i.e., /tmp/
> petara1/mpich2-1.2.1) and freshly created it again.
> 2> Configured as below  :-
>      /petara1/mpich2/mpich2-1.2.1/configure -prefix=/mpich2-install
> --with-devicech3:sock 2>&1 | tee c.txt
> 3> As ususal I saw the below error in c.txt file.
>     /petara1/mpich2/mpich2-1.2.1/src/mpid/ch3/configure:
> MY_EXPORTED_LIBS= -lpthread: is not an identifier
> 4> Modified file ( /tmp/petara1/mpich2-1.2.1/src/mpid/ch3/
> configure.lineno, line 7259 ) as suggested by you as:
>      MY_EXPORTED_LIBS="$LIBS"
>      export MY_EXPORTED_LIBS
> 5> Tried compiling again as:
>      make 2>&1 | tee m.txt
> 6> Fails with same reason
> Attaching new c.txt, m.txt and configure.log files.
> Cheers,
> -Arvind
> On Thu, Jan 21, 2010 at 6:06 PM, Dave Goodell <goodell at mcs.anl.gov>
> wrote:
> It looks like the CH3 configure step didn't entirely complete, so a
> bunch of configure-generated files are missing.  Line 454 of your
> previously attached c.txt is particularly suspect:
> --------8<--------
> --------8<--------
> Aha! As I'm writing this I think I see the problem.  There's a bash/
> zsh-ism in src/mpid/ch3/configure.in, line 311:
> --------8<--------
> export MY_EXPORTED_LIBS="$LIBS"
> --------8<--------
> I don't have the time to do it today, but I can try to build you a
> release tarball with a fixed version tomorrow.  The fix should be to
> separate out the assignment from the export:
> --------8<--------
> --------8<--------
> You are welcome to make that change yourself, but you'll need to
> regenerate the configure from the configure.in by running "./maint/
> updatefiles" in the source tree, which itself requires particular
> versions of the autotools and some other utilities.  Alternatively,
> you can edit "src/mpid/ch3/configure" in the build tree directly,
> but I can't tell you exactly which line to change.  You'll just have
> to search for MY_EXPORTED_LIBS and make the change wherever it is.
> -Dave
> On Jan 21, 2010, at 3:34 PM, Arvind Petaru wrote:
> same errors...
> On Thu, Jan 21, 2010 at 4:34 PM, Rajeev Thakur <thakur at mcs.anl.gov>
> wrote:
> Does it give the same error or a different error?
> Rajeev
> From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov
> ] On Behalf Of Arvind Petaru
> Sent: Thursday, January 21, 2010 3:32 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] Compilation of MPCH2-1.2.1 is failing
> Forgot to mention earlier....I tried that too(--with-
> device=ch3:sock) and it fails........
> -Arvind
> On Thu, Jan 21, 2010 at 4:27 PM, Rajeev Thakur <thakur at mcs.anl.gov>
> wrote:
> Can you try configuring with --with-device=ch3:sock (followed by
> make and make install) and see if that works?
> Rajeev
> Sent: Thursday, January 21, 2010 2:19 PM
> Subject: [mpich-discuss] Compilation of MPCH2-1.2.1 is failing on
> Hi,
>   I'm new to MPI programming.
>   I installed MPICH2 on my Sun Solaris 10, SPARC version and tried
> to configure & compile it on this machine.
>   I was not able to compile it successfully and it throws lot of
> errors. Not sure what could be the problem (or) if I am missing
> something.
>   I'd appreciate if someone can help me in this regards.
>   Attaching c.txt, m.txt, config.log, config.system and
> config.status files for your reference.
>    Let me know if you need any other info.
> Cheers,
> -Arvind
> Cheers,
> -Arvind
> mpich-discuss mailing list
> Cheers,
> -Arvind
> Cheers,
> -Arvind
> Cheers,
> -Arvind
> Cheers,
> -Arvind
