[mpich-discuss] Compilation of MPCH2-1.2.1 is failing onSunSolaris 10 (Sparc)
Arvind Petaru
arvindpetaru at gmail.com
Fri Jan 22 10:40:21 CST 2010
To add on more.....
I was compiling on bash shell.......and i tried below commands on bash shell
prompt and it works fine, so I don't think MY_EXPORTED_LIBS is creating
problem here:
lperf011-root>
lperf011-root> VAR=abcd
lperf011-root> echo $VAR
abcd
lperf011-root>
lperf011-root> export TMPVAR="$VAR"
lperf011-root> echo $TMPVAR
abcd
lperf011-root>
lperf011-root>
Also, there was a typo in my earlier mail for point 2, where it should be
"--with-device=ch3:sock" instead of "--with-devicech3:sock", missed a "="
symbol.....
-Arvind
On Fri, Jan 22, 2010 at 11:29 AM, Arvind Petaru <arvindpetaru at gmail.com>wrote:
> Hi Dave,
> Thanks for your suggestion.
> I tried compiling following your suggestion and I still see the same
> errors.
> Steps I followed:
> 1> Removed everything from previous tmp build directory (i.e.,
> /tmp/petara1/mpich2-1.2.1) and freshly created it again.
> 2> Configured as below :-
> /petara1/mpich2/mpich2-1.2.1/configure -prefix=/mpich2-install
> --with-devicech3:sock 2>&1 | tee c.txt
> 3> As ususal I saw the below error in c.txt file.
> /petara1/mpich2/mpich2-1.2.1/src/mpid/ch3/configure:
> MY_EXPORTED_LIBS= -lpthread: is not an identifier
> 4> Modified file ( /tmp/petara1/mpich2-1.2.1/src/mpid/ch3/configure.lineno,
> line 7259 ) as suggested by you as:
> MY_EXPORTED_LIBS="$LIBS"
> export MY_EXPORTED_LIBS
> 5> Tried compiling again as:
> make 2>&1 | tee m.txt
> 6> Fails with same reason
> Attaching new c.txt, m.txt and configure.log files.
> Cheers,
> -Arvind
> On Thu, Jan 21, 2010 at 6:06 PM, Dave Goodell <goodell at mcs.anl.gov>wrote:
>> It looks like the CH3 configure step didn't entirely complete, so a bunch
>> of configure-generated files are missing. Line 454 of your previously
>> attached c.txt is particularly suspect:
>> --------8<--------
>> /petara1/mpich2/mpich2-1.2.1/src/mpid/ch3/configure: MY_EXPORTED_LIBS=
>> --------8<--------
>> Aha! As I'm writing this I think I see the problem. There's a
>> bash/zsh-ism in src/mpid/ch3/configure.in, line 311:
>> --------8<--------
>> export MY_EXPORTED_LIBS="$LIBS"
>> --------8<--------
>> I don't have the time to do it today, but I can try to build you a release
>> tarball with a fixed version tomorrow. The fix should be to separate out
>> the assignment from the export:
>> --------8<--------
>> --------8<--------
>> You are welcome to make that change yourself, but you'll need to
>> regenerate the configure from the configure.in by running
>> "./maint/updatefiles" in the source tree, which itself requires particular
>> versions of the autotools and some other utilities. Alternatively, you can
>> edit "src/mpid/ch3/configure" in the build tree directly, but I can't tell
>> you exactly which line to change. You'll just have to search for
>> MY_EXPORTED_LIBS and make the change wherever it is.
>> -Dave
>> On Jan 21, 2010, at 3:34 PM, Arvind Petaru wrote:
>> same errors...
>>> On Thu, Jan 21, 2010 at 4:34 PM, Rajeev Thakur <thakur at mcs.anl.gov>
>>> wrote:
>>> Does it give the same error or a different error?
>>> Rajeev
>>> From: mpich-discuss-bounces at mcs.anl.gov [mailto:
>>> mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Arvind Petaru
>>> Sent: Thursday, January 21, 2010 3:32 PM
>>> To: mpich-discuss at mcs.anl.gov
>>> Subject: Re: [mpich-discuss] Compilation of MPCH2-1.2.1 is failing
>>> Forgot to mention earlier....I tried that too(--with-device=ch3:sock) and
>>> it fails........
>>> -Arvind
>>> On Thu, Jan 21, 2010 at 4:27 PM, Rajeev Thakur <thakur at mcs.anl.gov>
>>> wrote:
>>> Can you try configuring with --with-device=ch3:sock (followed by make and
>>> make install) and see if that works?
>>> Rajeev
>>> Sent: Thursday, January 21, 2010 2:19 PM
>>> Subject: [mpich-discuss] Compilation of MPCH2-1.2.1 is failing on
>>> Hi,
>>> I'm new to MPI programming.
>>> I installed MPICH2 on my Sun Solaris 10, SPARC version and tried to
>>> configure & compile it on this machine.
>>> I was not able to compile it successfully and it throws lot of errors.
>>> Not sure what could be the problem (or) if I am missing something.
>>> I'd appreciate if someone can help me in this regards.
>>> Attaching c.txt, m.txt, config.log, config.system and config.status
>>> files for your reference.
>>> Let me know if you need any other info.
>>> Cheers,
>>> -Arvind
>>> Cheers,
>>> -Arvind
>>> _______________________________________________
>>> mpich-discuss mailing list
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>>> Cheers,
>>> -Arvind
>>> Cheers,
>>> -Arvind
> Cheers,
> -Arvind
Cheers,
-Arvind
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100122/56a364fa/attachment.htm>
