[mpich-discuss] New communicator from connect/accept primitives
Rajeev Thakur
thakur at mcs.anl.gov
Tue Jan 19 20:01:22 CST 2010
Why don't you call your client as A, servers as B and C, and follow the algorithm below exactly:
> * begin by doing an MPI_Intercomm_merge on AB_inter, resulting in an
> intracommunicator AB_intra.
> * then create an intercommunicator between AB on one side and C on the
> other by using MPI_Intercomm_create. Pass AB_intra as the local_comm
> on A and B, MPI_COMM_WORLD as the intracomm on C, and AC_inter as the
> peer_comm. This results in the intercommunicator AB_C_inter.
> * then call MPI_Intercomm_merge on it to create the intracommunicator
> ABC_intra.
Rajeev
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of
> Francisco Javier García Blas
> Sent: Monday, January 18, 2010 10:26 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] New communicator from
> Hello again,
> In first place, thanks for response of Rajeev and Jayesh.
> Following Rajeev 's instruccion, I implemented an basic
> example using connect/accept and intercomm_create/merge
> primitives. I am doing something wrong because when
> MPI_Intercomm_create is invoked, all the processes become
> blocked. I don't find the error, maybe it could be a bad
> numeration in local and remote communicator but I tried all
> the combinations.
> I am using mpich2 1.0.5.
> I attach the source code and a makefile.
> Best regards
> Rajeev Thakur escribió:
> > You will need to use intercomm_merge but you have to merge them one
> > pair at a time. Example below from an old mail.
> > Rajeev
> > If you have 3 intercommunicators AB_inter, AC_inter, and
> AD_inter, you
> > can merge them all into a single intercommunicator as follows:
> resulting in an
> and C on the
> local_comm
> AC_inter as the
> intracommunicator
> > ABC_intra.
> > * then call MPI_Intercomm_create to create an intercommunicator
> > between ABC and D just as you did with AB and C above.
> > * Again do an intercomm_merge. This will give you an
> intracommunicator
> > containing A, B, C, D.
> > * If you want an intercommunicator with A in one group and B,C,D in
> > the other, as you would get with a single spawn of 3 processes, you
> > have to call MPI_Comm_split to split this single
> communicator into two
> > intracommunicators, one containing A and the other
> containing B,C,D.
> > Then call MPI_Intercomm_create to create the intercommunicator.
> > *From:* mpich-discuss-bounces at mcs.anl.gov
> > [mailto:mpich-discuss-bounces at mcs.anl.gov] *On Behalf Of
> > *Francisco Javier García Blas
> > *Sent:* Friday, January 15, 2010 11:09 AM
> > *To:* mpich-discuss at mcs.anl.gov
> > *Subject:* [mpich-discuss] New communicator from connect/accept
> > primitives
> > Hello all,
> > I wondering the possibility of get a new
> inter-comunicator from N
> > communicators, which are results from different calls of
> > mpi_comm_connect or mpi_comm_accept.
> > My initial solution was first, to get the group of each
> > inter-communicator with mpi_comm_group, second, to join all the
> > groups into one bigger and finally, to create a new communicator
> > from the group with the mpi_comm_create primitive.
> > Currently I am handling a pool of inter - communicators in order
> > to keep the functionality. However this idea is not suitable for
> > collective and MPI_ANY_SOURCE sends/recvs.
> > Exist another way to join all the inter-communicator
> into one?
> > Any suggestion?
> > Best regards.
> > Computer Architecture, Communications and Systems Area.
> > Computer Science Department. UNIVERSIDAD CARLOS III DE MADRID
> > Avda. de la Universidad, 30
> > 28911 Leganés (Madrid), SPAIN
> > e-mail: fjblas at arcos.inf.uc3m.es
> <mailto:fjblas at arcos.inf.uc3m.es>
> > fjblas at inf.uc3m.es <mailto:fjblas at inf.uc3m.es>
> > Phone:(+34) 916249118
> > FAX: (+34) 916249129
> > _______________________________________________
> > mpich-discuss mailing list
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
