[mpich-discuss] New communicator from connect/accept primitives
jayesh at mcs.anl.gov jayesh at mcs.anl.gov
Tue Jan 19 13:52:53 CST 2010
 Rajeev, correct me if I got it wrong...
 On the client side when creating the intercommunicator you should specify the client_B intercommunicator with the client_A intracommunicator (MPI_Intercomm_create( comm_agg, 0,  pool_comm[1], 1, 12345  , &comm_aux ); ).
 Similarly on the server B side you should specify the client_B intercommunicator with the local communicator in B (MPI_Intercomm_create( comm_world, 0, comm_inter, 0, 12345 , &comm_aux );
 Let us know if it works.
Jayesh
----- Original Message -----
From: "Francisco Javier García Blas" <fjblas at arcos.inf.uc3m.es>
To: jayesh at mcs.anl.gov
Cc: mpich-discuss at mcs.anl.gov
Sent: Tuesday, January 19, 2010 10:20:46 AM GMT -06:00 US/Canada Central
Subject: Re: [mpich-discuss] New communicator from connect/accept primitives
Hi Jayesh,
I haven't problem with MPI_Intercomm_merge. I tried to merge using different directions successfully. I checked also the size of the new intracommunicator after merging and it is correct too (size 2).
Additionally, yesterday I tried with MPI_Comm_spawn + MPI_Intercomm_create examples at testcase without problems. In these cases all the processes on the same group have same intercommunicators. However, in my case, I am doing something wrong when three processes call MPI_Intercomm_create over two remote groups. (AB intra, C inter). Arguments mistake maybe?
As suggested Dave, I tried my example with the lasted stable version of MPICH2, with similar results.
Thanks for all
Regards
El 19/01/2010, a las 16:22, jayesh at mcs.anl.gov escribió:
I haven't looked at your code yet. You can look at the testcase, testconnect.c ( https://svn.mcs.anl.gov/repos/mpi/mpich2/trunk/test/mpi/manual/testconnect.c ), in the MPICH2 test suite for a simple example on how to use connect/accept and intercomm_merge to create an intracommunicator.
-Jayesh
From: "Francisco Javier García Blas" < fjblas at arcos.inf.uc3m.es >
Sent: Monday, January 18, 2010 10:26:08 AM GMT -06:00 US/Canada Central
Hello again,
In first place, thanks for response of Rajeev and Jayesh. Following
Rajeev 's instruccion, I implemented an basic example using
connect/accept and intercomm_create/merge primitives. I am doing
something wrong because when MPI_Intercomm_create is invoked, all the
processes become blocked. I don't find the error, maybe it could be a
bad numeration in local and remote communicator but I tried all the
combinations.
I am using mpich2 1.0.5.
I attach the source code and a makefile.
Best regards
Rajeev Thakur escribió:
You will need to use intercomm_merge but you have to merge them one
pair at a time. Example below from an old mail.
Rajeev
If you have 3 intercommunicators AB_inter, AC_inter, and AD_inter, you
can merge them all into a single
intercommunicator as follows:
* begin by doing an MPI_Intercomm_merge on AB_inter, resulting in an
intracommunicator AB_intra.
* then create an intercommunicator between AB on one side and C on the
other
by using MPI_Intercomm_create. Pass AB_intra as the local_comm on A and B,
MPI_COMM_WORLD as the intracomm on C, and AC_inter as the peer_comm. This
results in the intercommunicator AB_C_inter.
* then call MPI_Intercomm_merge on it to create the intracommunicator
ABC_intra.
* then call MPI_Intercomm_create to create an intercommunicator
between ABC
and D just as you did with AB and C above.
* Again do an intercomm_merge. This will give you an intracommunicator
containing A, B, C, D.
* If you want an intercommunicator with A in one group and B,C,D in the
other, as you would get with a single spawn of 3 processes, you have
to call
MPI_Comm_split to split this single communicator into two
intracommunicators, one containing A and the other containing B,C,D. Then
call MPI_Intercomm_create to create the intercommunicator.
[mailto:mpich-discuss-bounces at mcs.anl.gov] *On Behalf Of
*Francisco Javier García Blas
*Sent:* Friday, January 15, 2010 11:09 AM
*To:* mpich-discuss at mcs.anl.gov
*Subject:* [mpich-discuss] New communicator from connect/accept
primitives
Hello all,
I wondering the possibility of get a new inter-comunicator from N
communicators, which are results from different calls of
mpi_comm_connect or mpi_comm_accept.
My initial solution was first, to get the group of each
inter-communicator with mpi_comm_group, second, to join all the
groups into one bigger and finally, to create a new communicator
from the group with the mpi_comm_create primitive.
Currently I am handling a pool of inter - communicators in order
to keep the functionality. However this idea is not suitable for
collective and MPI_ANY_SOURCE sends/recvs.
Exist another way to join all the inter-communicator into one?
Any suggestion?
Best regards.
Computer Architecture, Communications and Systems Area.
Computer Science Department. UNIVERSIDAD CARLOS III DE MADRID
Avda. de la Universidad, 30
28911 Leganés (Madrid), SPAIN
e-mail: fjblas at arcos.inf.uc3m.es < mailto:fjblas at arcos.inf.uc3m.es >
fjblas at inf.uc3m.es < mailto:fjblas at inf.uc3m.es >
Phone:(+34) 916249118
FAX: (+34) 916249129
mpich-discuss mailing list
