[mpich-discuss] New communicator from connect/accept primitives
Francisco Javier García Blas
fjblas at arcos.inf.uc3m.es
Tue Jan 19 10:20:46 CST 2010
Hi Jayesh,
I haven't problem with MPI_Intercomm_merge. I tried to merge using different directions successfully. I checked also the size of the new intracommunicator after merging and it is correct too (size 2).
Additionally, yesterday I tried with MPI_Comm_spawn + MPI_Intercomm_create examples at testcase without problems. In these cases all the processes on the same group have same intercommunicators. However, in my case, I am doing something wrong when three processes call MPI_Intercomm_create over two remote groups. (AB intra, C inter). Arguments mistake maybe?
As suggested Dave, I tried my example with the lasted stable version of MPICH2, with similar results.
Thanks for all
Regards
El 19/01/2010, a las 16:22, jayesh at mcs.anl.gov escribió:
> Hi,
> I haven't looked at your code yet. You can look at the testcase, testconnect.c (https://svn.mcs.anl.gov/repos/mpi/mpich2/trunk/test/mpi/manual/testconnect.c), in the MPICH2 test suite for a simple example on how to use connect/accept and intercomm_merge to create an intracommunicator.
> -Jayesh
> From: "Francisco Javier García Blas" <fjblas at arcos.inf.uc3m.es>
> To: mpich-discuss at mcs.anl.gov
> Sent: Monday, January 18, 2010 10:26:08 AM GMT -06:00 US/Canada Central
> Subject: Re: [mpich-discuss] New communicator from connect/accept primitives
> Hello again,
> In first place, thanks for response of Rajeev and Jayesh. Following
> Rajeev 's instruccion, I implemented an basic example using
> connect/accept and intercomm_create/merge primitives. I am doing
> something wrong because when MPI_Intercomm_create is invoked, all the
> processes become blocked. I don't find the error, maybe it could be a
> bad numeration in local and remote communicator but I tried all the
> combinations.
> I am using mpich2 1.0.5.
> I attach the source code and a makefile.
> Best regards
> Rajeev Thakur escribió:
>> You will need to use intercomm_merge but you have to merge them one
>> pair at a time. Example below from an old mail.
>> Rajeev
>> If you have 3 intercommunicators AB_inter, AC_inter, and AD_inter, you
>> can merge them all into a single
>> intercommunicator as follows:
>> * begin by doing an MPI_Intercomm_merge on AB_inter, resulting in an
>> intracommunicator AB_intra.
>> * then create an intercommunicator between AB on one side and C on the
>> other
>> by using MPI_Intercomm_create. Pass AB_intra as the local_comm on A and B,
>> MPI_COMM_WORLD as the intracomm on C, and AC_inter as the peer_comm. This
>> results in the intercommunicator AB_C_inter.
>> * then call MPI_Intercomm_merge on it to create the intracommunicator
>> ABC_intra.
>> * then call MPI_Intercomm_create to create an intercommunicator
>> between ABC
>> and D just as you did with AB and C above.
>> * Again do an intercomm_merge. This will give you an intracommunicator
>> containing A, B, C, D.
>> * If you want an intercommunicator with A in one group and B,C,D in the
>> other, as you would get with a single spawn of 3 processes, you have
>> to call
>> MPI_Comm_split to split this single communicator into two
>> intracommunicators, one containing A and the other containing B,C,D. Then
>> call MPI_Intercomm_create to create the intercommunicator.
>> *From:* mpich-discuss-bounces at mcs.anl.gov
>> [mailto:mpich-discuss-bounces at mcs.anl.gov] *On Behalf Of
>> *Francisco Javier García Blas
>> *Sent:* Friday, January 15, 2010 11:09 AM
>> *To:* mpich-discuss at mcs.anl.gov
>> *Subject:* [mpich-discuss] New communicator from connect/accept
>> primitives
>> Hello all,
>> I wondering the possibility of get a new inter-comunicator from N
>> communicators, which are results from different calls of
>> mpi_comm_connect or mpi_comm_accept.
>> My initial solution was first, to get the group of each
>> inter-communicator with mpi_comm_group, second, to join all the
>> groups into one bigger and finally, to create a new communicator
>> from the group with the mpi_comm_create primitive.
>> Currently I am handling a pool of inter - communicators in order
>> to keep the functionality. However this idea is not suitable for
>> collective and MPI_ANY_SOURCE sends/recvs.
>> Exist another way to join all the inter-communicator into one?
>> Any suggestion?
>> Best regards.
>> Computer Architecture, Communications and Systems Area.
>> Computer Science Department. UNIVERSIDAD CARLOS III DE MADRID
>> Avda. de la Universidad, 30
>> 28911 Leganés (Madrid), SPAIN
>> e-mail: fjblas at arcos.inf.uc3m.es <mailto:fjblas at arcos.inf.uc3m.es>
>> fjblas at inf.uc3m.es <mailto:fjblas at inf.uc3m.es>
>> Phone:(+34) 916249118
>> FAX: (+34) 916249129
>> mpich-discuss mailing list
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100119/06c7c2e6/attachment.htm>
