[mpich-discuss] problems with mpich2 configure
jaharvey at chem.umass.edu jaharvey at chem.umass.edu
Tue Jan 12 19:38:26 CST 2010
Would a re-install of GCC fix this problem?
Jacob
On Tue, Jan 12, 2010 at 5:43 PM, Dave Goodell <goodell at mcs.anl.gov> wrote:
     It looks like your C++ compiler installation isn't in the best
shape (see the quoted passage at the bottom of this mail for an
example).  If you don't need C++ support in your mpich2 installation
you can configure with --disable-cxx. Otherwise I would work on
getting your C++ compiler working on simple programs before attempting
to build mpich2.
     -Dave
     -------8<-------
     configure:12111: checking whether C++ compiler works with string
     configure:12145: c++ -c -m64
-I/opt/src/mpich2-1.2.1/src/openpa/src
-I/opt/src/mpich2-1.2.1/src/openpa/src conftest.cpp >&5
     In file included from conftest.cpp:29:
/usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../../include/c++/3.4.6/string:45:28: bits/c++config.h: No such file or
directory
/usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../../include/c++/3.4.6/bits/stl_algobase.h:70,
                     from
/usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../../include/c++/3.4.6/bits/char_traits.h:46,
                     from
/usr/lib/gcc/x86_64-redhat-linux/3.4.6/../../../../include/c++/3.4.6/string:47,
     -------8<-------
     [trimming lots more error output from the same test]
     -------8<-------
     configure:12152: $? = 1
     configure: failed program was:
     | /* confdefs.h.  */
     | #define PACKAGE_NAME ""
     | #define PACKAGE_TARNAME ""
     | #define PACKAGE_VERSION ""
     | #define PACKAGE_STRING ""
     | #define PACKAGE_BUGREPORT ""
     | #define USE_SMP_COLLECTIVES 1
     | #define HAVE_ERROR_CHECKING MPID_ERROR_LEVEL_ALL
     | #define MPICH_ERROR_MSG_LEVEL MPICH_ERROR_MSG_ALL
     | #define USE_LOGGING MPID_LOGGING_NONE
     | #define HAVE_RUNTIME_THREADCHECK 1
     | #define MPICH_THREAD_LEVEL MPI_THREAD_MULTIPLE
     | #define USE_THREAD_IMPL MPICH_THREAD_IMPL_GLOBAL_MUTEX
     | #define MPIU_THREAD_GRANULARITY MPIU_THREAD_GRANULARITY_GLOBAL
     | #define MPIU_HANDLE_ALLOCATION_METHOD MPIU_HANDLE_ALLOCATION_MUTEX
     | #define MPIU_THREAD_REFCOUNT MPIU_REFCOUNT_NONE
     | #define HAVE_ROMIO 1
     | #define HAVE__FUNC__ /**/
     | #define HAVE__FUNCTION__ /**/
     | #define HAVE_PRAGMA_WEAK 1
     | #define USE_WEAK_SYMBOLS 1
     | #define HAVE_MULTIPLE_PRAGMA_WEAK 1
     | #define HAVE_LONG_LONG 1
     | #define F77_NAME_LOWER_2USCORE 1
     | #define STDCALL
     | #define HAVE_MPI_F_INIT_WORKS_WITH_C 1
     | #define HAVE_FORTRAN_BINDING 1
     | /* end confdefs.h.  */
     | #include <string>
     | int
     | main ()
     | return 0;
     |   return 0;
     configure:12173: result: no
     configure:12176: WARNING: The C++ compiler c++ cannot compile a
program containing the <string> header - this may indicate a problem
with the C++ installation.  Consider configuing with --disable-cxx
     -------8<-------
     On Jan 12, 2010, at 4:21 PM, jaharvey at chem.umass.edu wrote:
         Dear all,
         Here is my config.log file. Looks like I got errors is a few
places but I'm not sure which ones are the offending ones.
         Jacob
         On Tue, Jan 12, 2010 at 5:08 PM, Dave Goodell
           Hi Jacob, can you also send your config.log?  Configure
doesn't think that your C++ compiler is in the best shape, but the
exact error messages will be contained in the config.log.
           -Dave
           On Jan 12, 2010, at 3:55 PM, jaharvey at chem.umass.edu wrote:
               Dear MPICH2 community,
               I am trying to install MPICH2-1.2.1 on my 26 node
cluster running CentOS. I want to compile two versions of
MPICH2-1.2.1, one for 64 bit machines and the other for 32 bit
machines. So for the 64 bit machines I have given the following command:
               ./configure --prefix=/opt/mpich2-1.2.1-i86 CFLAGS=-m64
FFLAGS=-m64 F90FLAGS=-m64 CXXFLAGS=-m64 2>&1 | tee c.txt
               However, when I run this the configuration process ends
abruptly with the following errors:
               configure: error: C++ compiler
/opt/src/mpich2-1.2.1/bin/mpicxx  has neither iostream nor iostream.h.
               configure: error: ./configure failed for test/mpi
               I am indeed on a 64 bit machine when running
./configure. I have attached my c.txt file. Any help would be greatly
appreciated.
               Jacob Harvey
               <c.txt>_______________________________________________
               mpich-discuss mailing list
               mpich-discuss at mcs.anl.gov
         <config.log>_______________________________________________
