[mpich-discuss] MPICH2 1.2.1 build problem on Solaris 5.10
Dave Goodell goodell at mcs.anl.gov
Thu Feb 25 11:05:53 CST 2010
Please send us your c.txt, config.log, and src/mpid/ch3/channels/
nemesis/config.log files.  This will help us to figure out what went
wrong in the configure test.
After you do that, you should be able to get going again by changing
src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp/tcp_getip.c:61 from
this
------8<-------
#if defined(SIOCGIFCONF) && defined(HAVE_STRUCT_IFCONF)
------8<-------
to this
------8<-------
#if 0
------8<-------
After making this change you won't be able to choose your TCP
communication interface in MPICH2.
-Dave
On Feb 24, 2010, at 4:54 PM, chong tan wrote:
> Soory, mistake, it did not work with 1.2.1p1 either.
> with this config:
> setenv CFLAGS "-O3 -m32"
> setenv MPICH2LIB_CFLAGS "-O3 -m32"
> ./configure --prefix=/home/chong/install_dir/mpich2/mpich2.1.21p1/
> solaris_10   \
>     --disable-f90 --disable-f77 \
>     --enable-fast \
>     --verbose \
>     --enable-threads=single
> I got this error:
>   CC              tcp_getip.c
> tcp_getip.c: In function `MPIDI_GetIPInterface':
> tcp_getip.c:108: sizeof applied to an incomplete type
> tcp_getip.c:113: storage size of `ifconf' isn't known
> tcp_getip.c:140: sizeof applied to an incomplete type
> tcp_getip.c:157: dereferencing pointer to incomplete type
> tcp_getip.c:160: dereferencing pointer to incomplete type
> tcp_getip.c:163: dereferencing pointer to incomplete type
> tcp_getip.c:205: sizeof applied to an incomplete type
> tcp_getip.c:209: dereferencing pointer to incomplete type
> *** Error code 1
> looks like it is in directory mpich2-1.2.1p1/src/mpid/ch3/channels/
> nemesis/nemesis/netmod.
> I will keep probing a little further.  if you have any suggestion,
> please
> let me know.
> thanks
> tan
> From: chong tan <chong_guan_tan at yahoo.com>
> To: mpich-discuss at mcs.anl.gov
> Sent: Wed, February 24, 2010 1:54:41 PM
> Subject: Re: [mpich-discuss] MPICH2 1.2.1 build problem on Solaris
> 5.10
> Dave,
> 1.2.1p1 works.  If possible, please put a note on 1.2.1 that it is
> not for Solaris.
> thanks
> tan
> From: Dave Goodell <goodell at mcs.anl.gov>
> Sent: Wed, February 24, 2010 1:21:14 PM
> 5.10
> The "cannot find include file" errors that you are getting indicate
> that one or more sub-configure scripts did not run successfully but
> somehow did not cause failure at configure-time.
> If you are not hitting the issue described in #992, then in order to
> help I will need to see your c.txt and config.log files as described
> in the MPICH2 README.  I do still recommend starting with 1.2.1p1
> and debugging from there.  It contains a number of useful bug fixes.
> -Dave
> On Feb 24, 2010, at 3:11 PM, chong tan wrote:
> > Dave,
> > No, I already 'hacked' that line.  I ran into other error with
> that line.
> > I will see if I have any luck with 1.2.1p1.
> > tan
> > Sent: Wed, February 24, 2010 10:47:30 AM
> 5.10
> > I think you are hitting this issue: https://trac.mcs.anl.gov/projects/mpich2/ticket/992
> > The recently-released MPICH2 1.2.1p1 fixes this problem.  Please
> try that instead and let us know if you are still encountering
> problems.
> > -Dave
> > On Feb 24, 2010, at 11:46 AM, chong tan wrote:
> > > I have tried GCC and Solaris C, getting pretty much the same
> errors.
> > > configuration:
> > > ./configure --prefix=<my_install_dir> \
> > >        --enable-fast \
> > >        --verbose \
> > > with this configuration, I get this error:
> > > In file included from ../../../include/mpiimpl.h:120,
> > >                  from /home/chong/tools/MPICH2/mpich2-1.2.1/src/
> mpid/ch3/include/mpidimpl.h:22,
> > >                  from mpidu_process_locks.h:20,
> > >                  from mpidu_process_locks.c:6:
> > > /home/chong/tools/MPICH2/mpich2-1.2.1/src/mpid/ch3/include/
> mpidpre.h:13:28: mpidi_ch3_conf.h: No such file or directory
> > > If I specify --with-device=ch3:ssm, I get this error, among
> others:
> > > "/home/chong/tools/MPICH2/mpich2-1.2.1/src/mpid/ch3/include/
> mpidpre.h", line 13: cannot find include file: "mpidi_ch3_conf.h"
> > > any suggestion ?
> > > thanks
> > > tan
> > > _______________________________________________
> > > mpich-discuss mailing list
> > > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
