[mpich-discuss] MPICH2 1.2.1 build problem on Solaris 5.10
chong tan chong_guan_tan at yahoo.com
Wed Feb 24 16:54:02 CST 2010
Soory, mistake, it did not work with 1.2.1p1 either.
with this config:
setenv CFLAGS "-O3 -m32"
setenv MPICH2LIB_CFLAGS "-O3 -m32"
./configure --prefix=/home/chong/install_dir/mpich2/mpich2.1.21p1/solaris_10   \
    --disable-f90 --disable-f77 \
    --enable-fast \
    --verbose \
    --enable-threads=single
I got this error:
  CC              tcp_getip.c
tcp_getip.c: In function `MPIDI_GetIPInterface':
tcp_getip.c:108: sizeof applied to an incomplete type
tcp_getip.c:113: storage size of `ifconf' isn't known
tcp_getip.c:140: sizeof applied to an incomplete type
tcp_getip.c:157: dereferencing pointer to incomplete type
tcp_getip.c:160: dereferencing pointer to incomplete type
tcp_getip.c:163: dereferencing pointer to incomplete type
tcp_getip.c:205: sizeof applied to an incomplete type
tcp_getip.c:209: dereferencing pointer to incomplete type
*** Error code 1
looks like it is in directory mpich2-1.2.1p1/src/mpid/ch3/channels/nemesis/nemesis/netmod.
I will keep probing a little further.  if you have any suggestion, please
let me know.
thanks
tan
Sent: Wed, February 24, 2010 1:54:41 PM
Subject: Re: [mpich-discuss] MPICH2 1.2.1 build problem on Solaris 5.10
Dave,
1.2.1p1 works.  If possible, please put a note on 1.2.1 that it is not for Solaris.
thanks
tan
Sent: Wed, February 24, 2010 1:21:14 PM
The "cannot find include file" errors that you are getting indicate that one or more sub-configure scripts did not run successfully but somehow did not cause failure at configure-time.
If you are not hitting the issue described in #992, then in order to help I will need to see your c.txt and config.log files as described in the MPICH2 README.  I do still recommend starting with 1.2.1p1 and debugging from there.  It contains a number of useful bug fixes.
-Dave
On Feb 24, 2010, at 3:11 PM, chong tan wrote:
> Dave,
> No, I already 'hacked' that line.  I ran into other error with that line.
> I will see if I have any luck with 1.2.1p1.
> tan
> From: Dave Goodell <goodell at mcs.anl.gov>
> Sent: Wed, February 24, 2010 10:47:30 AM
> I think you are hitting this issue: https://trac.mcs.anl.gov/projects/mpich2/ticket/992
> The recently-released MPICH2 1.2.1p1 fixes this problem.  Please try that instead and let us know if you are still encountering problems.
> -Dave
> On Feb 24, 2010, at 11:46 AM, chong tan wrote:
> > I have tried GCC and Solaris C, getting pretty much the same errors.
> > configuration:
> > ./configure --prefix=<my_install_dir> \
> >        --enable-fast \
> >        --verbose \
> > with this configuration, I get this error:
> > In file included from ../../../include/mpiimpl.h:120,
> >                  from /home/chong/tools/MPICH2/mpich2-1.2.1/src/mpid/ch3/include/mpidimpl.h:22,
> >                  from mpidu_process_locks.h:20,
> >                  from mpidu_process_locks.c:6:
> > /home/chong/tools/MPICH2/mpich2-1.2.1/src/mpid/ch3/include/mpidpre.h:13:28: mpidi_ch3_conf.h: No such file or directory
> > If I specify --with-device=ch3:ssm, I get this error, among others:
> > "/home/chong/tools/MPICH2/mpich2-1.2.1/src/mpid/ch3/include/mpidpre.h", line 13: cannot find include file: "mpidi_ch3_conf.h"
> > any suggestion ?
> > thanks
> > tan
> > _______________________________________________
> > mpich-discuss mailing list
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100224/691c682b/attachment.htm>
