[mpich-discuss] Can I run MPI program without mpirun/mpiexec?
John Xu
johnzxu at gmail.com
Wed Feb 24 01:50:23 CST 2010
In src/mpid/ch3/channels/shm/configure, should the following code to
be conditioned with
if test "$cross_compiling" = yes; then ?
# Check for memory atomic instructions
{ $as_echo "$as_me:$LINENO: checking for x86 mfence instruction using
__asm__" >&5
$as_echo_n "checking for x86 mfence instruction using __asm__... " >&6; }
if test "${pac_cv_have_gcc_asm_and_x86_mfence+set}" = set; then
$as_echo_n "(cached) " >&6
else
I am not familiar with this at all, just wondering if there is
anything that could be done here.
thanks,
john
On Wed, Feb 24, 2010 at 1:14 AM, John Xu <johnzxu at gmail.com> wrote:
> Thanks, Dave and Pavan.
> I tried both hydra and gforker and it appears gforker is easier to
> use. I can now
> start two processes in a 2 core ALPHA SMP processor.
> I used ch3:sock and my program got stuck at beginning of the simulation
> Process 0 of 2 is on (none)
> Process 1 of 2 is on (none)
> I think this is due to network socket problem with my simulator.
> Then I switched to ch3:nemesis, I got the following errors:
> Fatal error in MPI_Init: Other MPI error, error stack:
> MPIR_Init_thread(394).....: Initialization failed
> MPID_Init(135)............: channel initialization failed
> MPIDI_CH3_Init(43)........:
> MPID_nem_init(202)........:
> MPIDI_CH3I_Seg_commit(346): generic failure with errno = 16
> [0]0:Return code = 1
> [0]1:Return code = 0, signaled with Interrupt
> At this point, all I need is a SMP MPI calls with shared memory, so I
> would really
> only need ch3:shm, but I got the configuration errors trying to
> configure with ch3:shm
> checking for sys/sysctl.h... yes
> checking for x86 mfence instruction using __asm__... configure: error:
> in `/home/john/benchmarks/mpich2/mpich2-1.2.1/src/mpid/ch3/channels/shm':
> configure: error: cannot run test program while cross compiling
> See `config.log' for more details.
> configure: error: ./configure failed for channels/shm
> configure: error: Configure of src/mpid/ch3 failed!
> It appears that there is a configuration error where even I am trying
> to cross compile for ALPHA, the configuration script
> is trying to use x86 instructions for shared memory locks.
> Any idea or recommendations on how to fix this problem?
> I saw a report in an early post in Nov last year about this as well
> but did not see any resolution on this.
> Your help will be greatly appreciated.
> john
> On Tue, Feb 23, 2010 at 5:42 PM, Dave Goodell <goodell at mcs.anl.gov> wrote:
>> You can try using the hydra process manager. It doesn't require Python:
>> http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager
>> -Dave
>> On Feb 23, 2010, at 5:25 PM, John Xu wrote:
>>> Hi, Dave.
>>> Thanks a lot for the email.
>>> The problem for me is that I had a major problem trying to cross-compile
>>> Python
>>> for alpha. Without Python, I can not use the good process managers
>>> MPICH2 provides.
>>> I am trying to see if there is anyway to run a statically compiled
>>> binary in a standalone
>>> fashion. According to Jayesh, it is possible. But I can not
>>> successfully run it myself.
>>> I am still wondering if there is any possibility to do this ...
>>> thanks,
>>> john
>>> On Tue, Feb 23, 2010 at 5:17 PM, Dave Goodell <goodell at mcs.anl.gov> wrote:
>>>> Basically, this won't work.
>>>> The process manager plays a necessary role in starting the MPI processes
>>>> and
>>>> bootstrapping their communication. It is extremely unlikely that you
>>>> will
>>>> be able to make something sensible work by running the processes yourself
>>>> and just twiddling a few environment variables (for more than a single
>>>> process, anyway).
>>>> -Dave
>>>> On Feb 23, 2010, at 5:06 PM, John Xu wrote:
>>>>> Hi,
>>>>> I ended up trying to setup the environment manually myself and got the
>>>>> program to run
>>>>> without mpiexec.
>>>>> However, the process I kicked off does not seems to reflect the number
>>>>> of processes
>>>>> I requested.
>>>>> For example, I set PMI_RANK = 0 and PMI_SIZE=2,
>>>>> but when I launched cpi, I got the following:
>>>>> Process 0 of 1 is on (none)
>>>>> pi is approximately 3.1415926544231332, Error is 0.0000000008333401
>>>>> wall clock time = 0.000976
>>>>> The total number of processes is 1 instead of 2.
>>>>> Any idea of what environment variable I need to set to get the desired
>>>>> behaviour?
>>>>> Thanks,
>>>>> john
>>>>> On Tue, Feb 23, 2010 at 4:25 PM, John Xu <johnzxu at gmail.com> wrote:
>>>>>> Hi,
>>>>>> I am trying to start up mpi process in a processor simulator
>>>>>> environment. So I have the same problem
>>>>>> as formerly posted in
>>>>>> https://lists.mcs.anl.gov/mailman/htdig/mpich-discuss/2009-November/006008.html
>>>>>> Jayesh,
>>>>>> You indicated that there is a way similar to the windows debugging by
>>>>>> starting processes at manually.
>>>>>> But it requires two command prompts.
>>>>>> Does it work for a linux environment running SMP with say 2 cores?
>>>>>> Since I only have one dummy term emulated from the simulator, I can
>>>>>> not get two command prompts.
>>>>>> Can I setup the environment as in your document and start two
>>>>>> processes in the background?
>>>>>> thanks,
>>>>>> john
>>>>>> Hi,
>>>>>> Yes, you can run an MPI program without mpiexec/mpirun. Let us know
>>>>>> if you have any problems.
>>>>>> Regards,
>>>>>> Jayesh
>>>>>> ----- Original Message -----
>>>>>> From: "junli gu" <gujunli at gmail.com>
>>>>>> To: mpich-discuss at mcs.anl.gov
>>>>>> Sent: Friday, November 20, 2009 2:58:30 PM GMT -06:00 US/Canada Central
>>>>>> Subject: [mpich-discuss] Can I run MPI program without mpirun/mpiexec?
>>>>>> Hi everyone:
>>>>>> I want to run mpi program like a normal binary without mpirun/mpiexec
>>>>>> command, like this: ./mpi_hello . Is this possible?
>>>>>> This is possible only that I can compile mpi program and put all the
>>>>>> runtime information into a stand alone binary. I don't know if it is
>>>>>> possible.
>>>>>> Thank you very much!
>>>>>> Junli Gu--谷俊丽
>>>>>> Coordinate Science Lab
>>>>>> University of Illinois at Urbana-Champaign
>>>>> _______________________________________________
>>>>> mpich-discuss mailing list
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
