[mpich-discuss] Can I run MPI program without mpirun/mpiexec?
John Xu johnzxu at gmail.com
Wed Feb 24 01:14:55 CST 2010
Thanks, Dave and Pavan.
I tried both hydra and gforker and it appears gforker is easier to
use. I can now
start two processes in a 2 core ALPHA SMP processor.
I used ch3:sock and my program got stuck at beginning of the simulation
Process 0 of 2 is on (none)
Process 1 of 2 is on (none)
I think this is due to network socket problem with my simulator.
Then I switched to ch3:nemesis, I got the following errors:
Fatal error in MPI_Init: Other MPI error, error stack:
MPIR_Init_thread(394).....: Initialization failed
MPID_Init(135)............: channel initialization failed
MPIDI_CH3_Init(43)........:
MPID_nem_init(202)........:
MPIDI_CH3I_Seg_commit(346): generic failure with errno = 16
[0]0:Return code = 1
[0]1:Return code = 0, signaled with Interrupt
At this point, all I need is a SMP MPI calls with shared memory, so I
would really
only need ch3:shm, but I got the configuration errors trying to
configure with ch3:shm
checking for sys/sysctl.h... yes
checking for x86 mfence instruction using __asm__... configure: error:
in `/home/john/benchmarks/mpich2/mpich2-1.2.1/src/mpid/ch3/channels/shm':
configure: error: cannot run test program while cross compiling
See `config.log' for more details.
configure: error: ./configure failed for channels/shm
configure: error: Configure of src/mpid/ch3 failed!
It appears that there is a configuration error where even I am trying
to cross compile for ALPHA, the configuration script
is trying to use x86 instructions for shared memory locks.
Any idea or recommendations on how to fix this problem?
I saw a report in an early post in Nov last year about this as well
but did not see any resolution on this.
Your help will be greatly appreciated.
john
On Tue, Feb 23, 2010 at 5:42 PM, Dave Goodell <goodell at mcs.anl.gov> wrote:
> You can try using the hydra process manager.  It doesn't require Python:
> http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager
> -Dave
> On Feb 23, 2010, at 5:25 PM, John Xu wrote:
>> Hi, Dave.
>> Thanks a lot for the email.
>> The problem for me is that I had a major problem trying to cross-compile
>> Python
>> for alpha. Without Python, I can not use the good process managers
>> MPICH2 provides.
>> I am trying to see if there is anyway to run a statically compiled
>> binary in a standalone
>> fashion. According to Jayesh, it is possible. But I can not
>> successfully run it myself.
>> I am still wondering if there is any possibility to do this ...
>> thanks,
>> john
>> On Tue, Feb 23, 2010 at 5:17 PM, Dave Goodell <goodell at mcs.anl.gov> wrote:
>>> Basically, this won't work.
>>> The process manager plays a necessary role in starting the MPI processes
>>> and
>>> bootstrapping their communication.  It is extremely unlikely that you
>>> will
>>> be able to make something sensible work by running the processes yourself
>>> and just twiddling a few environment variables (for more than a single
>>> process, anyway).
>>> -Dave
>>> On Feb 23, 2010, at 5:06 PM, John Xu wrote:
>>>> Hi,
>>>> I ended up trying to setup the environment manually myself and got the
>>>> program to run
>>>> without mpiexec.
>>>> However, the process I kicked off does not seems to reflect the number
>>>> of processes
>>>> I requested.
>>>> For example, I set PMI_RANK = 0 and PMI_SIZE=2,
>>>> but when I launched cpi, I got the following:
>>>> Process 0 of 1 is on (none)
>>>> pi is approximately 3.1415926544231332, Error is 0.0000000008333401
>>>> wall clock time = 0.000976
>>>> The total number of processes is 1 instead of 2.
>>>> Any idea of what environment variable I need to set to get the desired
>>>> behaviour?
>>>> Thanks,
>>>> john
>>>> On Tue, Feb 23, 2010 at 4:25 PM, John Xu <johnzxu at gmail.com> wrote:
>>>>> Hi,
>>>>> I am trying to start up mpi process in a processor simulator
>>>>> environment. So I have the same problem
>>>>> as formerly posted in
>>>>>  https://lists.mcs.anl.gov/mailman/htdig/mpich-discuss/2009-November/006008.html
>>>>> Jayesh,
>>>>> You indicated that there is a way similar to the windows debugging by
>>>>> starting processes at manually.
>>>>> But it requires two command prompts.
>>>>> Does it work for a linux environment running SMP with say 2 cores?
>>>>> Since I only have one dummy term emulated from the simulator, I can
>>>>> not get two command prompts.
>>>>> Can I setup the environment as in your document and start two
>>>>> processes in the background?
>>>>> thanks,
>>>>> john
>>>>>  Hi,
>>>>>  Yes, you can run an MPI program without mpiexec/mpirun. Let us know
>>>>> if you have any problems.
>>>>> Regards,
>>>>> Jayesh
>>>>> ----- Original Message -----
>>>>> From: "junli gu" <gujunli at gmail.com>
>>>>> To: mpich-discuss at mcs.anl.gov
>>>>> Sent: Friday, November 20, 2009 2:58:30 PM GMT -06:00 US/Canada Central
>>>>> Subject: [mpich-discuss] Can I run MPI program without mpirun/mpiexec?
>>>>> Hi everyone:
>>>>> I want to run mpi program like a normal binary without mpirun/mpiexec
>>>>> command, like this: ./mpi_hello . Is this possible?
>>>>> This is possible only that I can compile mpi program and put all the
>>>>> runtime information into a stand alone binary. I don't know if it is
>>>>> possible.
>>>>> Thank you very much!
>>>>> Junli Gu--谷俊丽
>>>>> Coordinate Science Lab
>>>>> University of Illinois at Urbana-Champaign
>>>> _______________________________________________
>>>> mpich-discuss mailing list
>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
