[mpich-discuss] Error relating compiling a program (sprng.h)?
    Rajeev Thakur
    thakur at mcs.anl.gov
    Sat Feb 20 09:47:13 CST 2010
SPRNG is a random number generator library that is separate from MPI.
See its user guide on how to compile and link the library.
http://sprng.cs.fsu.edu/Version4.0/compilation.html
Rajeev
  _____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of ESMAEILI AMIN
Sent: Saturday, February 20, 2010 5:21 AM
Subject: Re: [mpich-discuss] Error relating compiling a program
(sprng.h)?
Dear Rajeev
Hi
Many thanks for your help.
Ive added these line. And compiled with this:
amin at linux-usdz:~/Desktop/AminLinx> mpicc monte.c
and the result was as this:
monte.c:11:19: error: sprng.h: No such file or directory
monte.c: In function 'main':
monte.c:42: error: 'SPRNG_DEFAULT' undeclared (first use in this
function)
monte.c:42: error: (Each undeclared identifier is reported only once
monte.c:42: error: for each function it appears in.)
monte.c:42: warning: assignment makes pointer from integer without a
cast
I do not know, but maybe it is due to bad installation of MPICH2 or
OPENMPI, how can I assure that they`ve installed correctly?
Best Regards
Amin
On Sat, Feb 20, 2010 at 12:49 AM, Rajeev Thakur <thakur at mcs.anl.gov>
wrote:
Try adding a #define SIMPLE_SPRNG before #include <sprng.h>. Also move
the #define USE_MPI to before #include <sprng.h>
Rajeev
       Sent: Friday, February 19, 2010 7:34 AM
       Subject: [mpich-discuss] Error relating compiling a program
(sprng.h)?
       Dear Sir
       Hi
       Many thanks for your MPI package.
       I`ve installed the MPICH2 on my pc and made mpd.conf at HOME
directory
       But when I compile the program:
       I will get this error:
       monte.c:9:19: error: sprng.h:
       monte.c:40: error: 'SPRNG_DEFAULT' undeclared (first use in this
function)
       monte.c:40: error: (Each undeclared identifier is reported only
once
       monte.c:40: error: for each function it appears in.)
       monte.c:40: warning: assignment makes pointer from integer
without a cast
       amin at linux-usdz:~/Desktop/AminLinx> ..
       amin at linux-usdz:~/Desktop> ..
       amin at linux-usdz:~> cd Desktop/AminLinx/
       amin at linux-usdz:~/Desktop/AminLinx> mpirun monte.c
       problem with execution of monte.c  on  linux-usdz:  [Errno 2] No
       Plz help me to compile and run the program correctly.
       I`ve attched the program for your inform.
       Best Regards
       Sincerely
       Amin
mpich-discuss mailing list
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100220/12174684/attachment.htm>
