[mpich-discuss] Error relating compiling a program (sprng.h)?
ESMAEILI AMIN
amin at cavelab.cs.tsukuba.ac.jp
Sat Feb 20 05:21:17 CST 2010
Dear Rajeev
Hi
Many thanks for your help.
Ive added these line. And compiled with this:
amin at linux-usdz:~/Desktop/AminLinx> mpicc monte.c
and the result was as this:
monte.c:11:19: error: sprng.h: No such file or directory
monte.c: In function ‘main’:
monte.c:42: error: ‘SPRNG_DEFAULT’ undeclared (first use in this function)
monte.c:42: error: (Each undeclared identifier is reported only once
monte.c:42: error: for each function it appears in.)
monte.c:42: warning: assignment makes pointer from integer without a cast
I do not know, but maybe it is due to bad installation of MPICH2 or OPENMPI,
how can I assure that they`ve installed correctly?
Best Regards
Amin
On Sat, Feb 20, 2010 at 12:49 AM, Rajeev Thakur <thakur at mcs.anl.gov> wrote:
> Try adding a #define SIMPLE_SPRNG before #include <sprng.h>. Also move
> the #define USE_MPI to before #include <sprng.h>
> Rajeev
> ________________________________
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of ESMAEILI AMIN
> Sent: Friday, February 19, 2010 7:34 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: [mpich-discuss] Error relating compiling a program
> (sprng.h)?
> Dear Sir
> Hi
> Many thanks for your MPI package.
> I`ve installed the MPICH2 on my pc and made mpd.conf at HOME
> directory
> But when I compile the program:
> I will get this error:
> monte.c:9:19: error: sprng.h:
> monte.c: In function 'main':
> monte.c:40: error: 'SPRNG_DEFAULT' undeclared (first use in this
> function)
> monte.c:40: error: (Each undeclared identifier is reported only
> once
> monte.c:40: error: for each function it appears in.)
> monte.c:40: warning: assignment makes pointer from integer
> without a cast
> amin at linux-usdz:~/Desktop/AminLinx> ..
> amin at linux-usdz:~/Desktop> ..
> amin at linux-usdz:~> cd Desktop/AminLinx/
> amin at linux-usdz:~/Desktop/AminLinx> mpirun monte.c
> problem with execution of monte.c on linux-usdz: [Errno 2] No
> Plz help me to compile and run the program correctly.
> I`ve attched the program for your inform.
> Best Regards
> Sincerely
> Amin
> mpich-discuss mailing list
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20100220/864e4eca/attachment.htm>
