[mpich-discuss] make install issue
Tai Huynh thuynh at vni.com
Fri Feb 19 14:18:46 CST 2010
I did accidentally changed the line 197 in Makefile.in but that didn't work. Then I saw the email that say line 20 for Makefile.sm so I tried that too, but it did not work. Should I change both places?
Tai
-----Original Message-----
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Dave Goodell
Sent: Friday, February 19, 2010 2:15 PM
Subject: Re: [mpich-discuss] make install issue
When working from a source tarball of MPICH2, you will need to make
the change in "Makefile.in" and not "Makefile.sm", as I mentioned in
my previous email.  I accidentally gave you the line number from the
wrong file, sorry about that.  It should have been line 197 of
Makefile.in.
If you have all the proper versions of the GNU autotools (autoconf/
automake/libtool) available, you can try to re-run ./maint/updatefiles
to regenerate "Makefile.in" from "Makefile.sm".  But most people don't
have this setup readily available.
-Dave
On Feb 19, 2010, at 2:04 PM, Tai Huynh wrote:
> I made the changes to src/env/Makefile.sm at line 20. Did the re-run
> "configure" and "make install" but I still receive the same message.
> Tai
> Sent: Friday, February 19, 2010 1:07 PM
> We apparently have a non-portable invocation of "ln -sf" in "src/env/
> Makefile.sm".  To try to get yourself un-stuck you can change line 20
> of "src/env/Makefile.in" from:
> -------8<------
>             cd ${DESTDIR}${bindir} && ln -sf mpicxx mpic++ ; fi
> -------8<------
> to:
> -------8<------
>             cd ${DESTDIR}${bindir} && ln -f -s mpicxx mpic++ ; fi
> -------8<------
> (be careful to maintain the hard <TAB> at the beginning of the line)
> After making that change you will need to re-run "configure" and "make
> install".
> -Dave
> On Feb 19, 2010, at 12:58 PM, Tai Huynh wrote:
>> I have attached the mi.txt file you requested. I did the re-
>> configure, make, then make install all over again but still get this
>> error message.
>> -Tai
>> Sent: Friday, February 19, 2010 12:51 PM
>> I don't think you copied enough output for us to tell what happened.
>> Please run "make install 2>&1 | tee mi.txt" and send us the generated
>> mi.txt file.
>> -Dave
>> On Feb 19, 2010, at 11:37 AM, Tai Huynh wrote:
>>> That resolved the error for the install-sh but I'm getting another
>>> one:
>>> *** Error code 1
>>> make: Fatal error: Command failed for target `install-postamble'
>>> Current working directory /build/FNL7/tai/mpich2-1.2.1/src/env
>>> *** Error code 1
>>> make: Fatal error: Command failed for target `install'
>>> *** Error code 1
>>> -Tai
>>> Sent: Friday, February 19, 2010 11:25 AM
>>> It doesn't look like the problem is coming from MKDIR_P (although
>>> reading that macro I think I just spotted a separate bug there too).
>>> The problem is that our makefile is using "INSTALL_DATA=confdb/
>>> install-
>>> sh" as determined by AC_PROG_INSTALL [1] in a subdirectory.
>>> Because
>>> this is a relative path, when the make process changes directories
>>> it
>>> can no longer find the program.  Even worse than this being a
>>> relative
>>> path, it's a relative path with an implicit current directory (there
>>> is no explicit "." at the start).
>>> I suspect this happens because your machine doesn't have a proper
>>> "install" program written in C, so it falls back to using the
>>> included
>>> "install-sh".  We do all of our testing on platforms with working
>>> "install" programs, so we never see this case.
>>> The short term workaround for you is to re-configure and pass
>>> "INSTALL=MPICH2_SOURCE_DIR/confdb/install-sh", replacing
>>> "MPICH2_SOURCE_DIR" with a real path to the MPICH2 source
>>> distribution.  I'll file a new ticket to remind us to fix this up
>>> somehow.
>>> -Dave
>>> [1] http://www.gnu.org/software/autoconf/manual/autoconf.html#index-AC_005fPROG_005fINSTALL-262
>>> On Feb 19, 2010, at 8:48 AM, Tai Huynh wrote:
>>>> When I do a make install and it fails because confdb/install-sh is
>>>> not found.
>>>> My mpich2-1.2.1 already have the fix of r5801 (AC_PROG_MKDIR_P is
>>>> broken; it's using a version check on
>>>> mkdir to figure out whether to use "mkdir -p", instead of something
>>>> else. Also added a comment explaining this issue.).
>>>> https://trac.mcs.anl.gov/projects/mpich2/ticket/939
>>>> I am running on a:
>>>> SunOS stratego 5.10 Generic_141444-09 sun4u sparc SUNW,Sun-Fire-
>>>> V240
>>>> f95: Sun Fortran 95 8.3 SunOS_sparc Patch 127000-01 2007/07/18
>>>> Thank you for you help,
>>>> Tai Huynh
>>>> <install.txt>
>>>> _______________________________________________
>>>> mpich-discuss mailing list
>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>> <mi.txt>_______________________________________________
